Oil Sender Woes?
Have been searchin' and readin' - I think I have diagnosed my problem, but want to check and be sure I don't screw up my car, or underestimate the issues. Here's the deal: around a week ago, my oil pressure gauge pegged at 80. Just sat there and I didn't worry too much. On the way home from sitting a few days at the airport last night, it started bouncing from 80 to 0, and back.
Started getting "Service Vehicle Soon" warnings, "Check Gauges," etc. Got the thing home - seemed to be running just fine besides all the warnings. There are no issues at idle, and when I turn the ignition on, but DON'T start the car, the gauge goes up to maybe 60. I don't think it should.My assessment from the reading I have done is that this is likely a bad oil sender. Your assessment? If so, can I drive the car (to go get new tires and a replacement oil sender?)
Appreciate views - thanks all!
b.
b.
The car is clearing demonstrating classic symptoms of oil pressure sender failure. Another symptom is if the oil pressure reads 130 psi on your "Driver Information Center" - aka DIC.
Drive the car, get tires and either get the sending unit replaced or do it yourself.
-Alex
Change it out.
Its solved everyone else’s gauge reading problem.
Most likely yours too...
Here are 2 pic how to's
http://www.smokinvette.com/corvettef...ad.php?t=40599
http://forums.corvetteforum.com/c5-t...y-vectorz.html
Also here is a Oil Sensor Relocating Kit - pretty sweet "wish I done this"
http://www.dpecorvettes.com/gpage7.html
Mr.Bill
