The Factory Service Manual says the gap should be .060 on plugs for my 2002 LS1. You didn't specify what year your car was or engine it had.....
Actually a bulletin came out changing the gap from .60 to .40.
Information on New Spark Plugs and Gapping #03-06-04-060 - (Oct 24, 2003)
A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the spark plug has also changed. The new spark plug, P/N 12571164 with AC Delco P/N 41-985, is gapped to 1.01mm (0.040 inches) when the spark plug is made. The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used.
ok, that's what I needed to hear, these bad boys are properly gapped and MSD 8.5 wires are ready too. shame, i don't got the time to do the swap over....or do I
Not one of mine was properly gaped to .040, so I just regaped all of them. Do you know how it would mess the plug up by gaping them yourself?
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Everywhere I have read says the plugs are pre-gapped, If it isn't correct it says don't use them and don't try to gap them yourself, You can damage the ground tip and possibly break off in the cylinder.
