no heat on drivers side
Old Sep 24, 2011 | 05:08 PM
dan-t's Avatar
dan-t
Default no heat on drivers side
help!! its geting cold out and noticed only blowing heat out passenger side. i did a search but most were ac related.thanks in advance for any help. oh its a 98 vette
Old Sep 24, 2011 | 07:21 PM
jgump's Avatar
jgump
Pull some codes. Your servo actuator is broken. The gear inside is probally cracked.
Old Sep 25, 2011 | 11:02 AM
dan-t's Avatar
dan-t
i did but only history codes no current ones..
Old Sep 25, 2011 | 09:27 PM
FLrealty's Avatar
FLrealty
disconnect the battery over night and see what happens. Worked for me.
Old Sep 26, 2011 | 05:00 PM
dan-t's Avatar
dan-t
il try it thanks
Old Sep 26, 2011 | 10:19 PM
stellar048's Avatar
stellar048
Here is the procedure to get the actuator out. You could take it out and move the temp around and see if it moves. This would tell you if the actuator is bad.
AIR TEMPERATURE ACTUATOR REPLACEMENT - LEFT
REMOVAL PROCEDURE
Remove the front floor kick-up panel.
Remove the Bose module.
Disconnect the inside air temperature sensor aspirator duct.
3.1. Depress the duct retaining tab and remove the duct from the ignition switch housing bracket.
3.2. Use a twisting motion to release the duct from the duct muffler.
Remove the inside air temperature sensor aspirator duct muffler. Use a twisting motion to release the duct muffler.
Disconnect the air temperature actuator electrical connector.
Remove the air temperature actuator screws.
Remove the air temperature actuator.
INSTALLATION PROCEDURE
Position the air temperature actuator, then align the slots in the actuator driver to the flats on the temperature door shaft.
Slide the air temperature actuator onto the shaft, while aligning the actuator locating hole to the forward alignment pin on the HVAC module case.The actuator should be completely seated onto the temperature door shaft and be the actuator mounting holes should be flush with the mounting bosses on the HVAC module case.
Install the temperature actuator retaining screws.
NOTE: Refer to Fastener Notice in Service Precautions.
Tighten
Tighten the screws to............1.5 N.m (13 lb in) .
Connect the air temperature actuator electrical connector.
Install the inside air temperature sensor aspirator duct muffler. Use a twisting motion to secure the duct muffler.
Install the inside air temperature sensor aspirator duct.
6.1. Use a twisting motion to secure the duct to the duct muffler.
6.2. Install the duct retaining tab to the ignition switch housing bracket.
Install the Bose amplifier.
Install the front floor kick-up panel.
Recalibrate the actuators. Refer to Re-Calibrating Actuators.
Old Sep 26, 2011 | 10:29 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
I had the reverse issue. Wanted A/C and had heat coming out driver vents and A/C out of the passanger side. Posted the issue in a thread and got two opinions. Bad drivers side actuator or possibly actuatior needed to be reset by clearing the codes.
Well the easiest thing to try was to clear the codes and see if it recalibrated the actuator. So far that solution has worked.
Old Sep 26, 2011 | 10:35 PM
stellar048's Avatar
stellar048
That too ...here's how to re-calibrate if you don't know
RE-CALIBRATING ACTUATORS
Use the following steps to perform the calibration update:
Turn OFF the ignition.
Remove the battery positive voltage circuit fuse of the HVAC Control Module.
Wait 60 seconds .
IMPORTANT: The module memory will not clear if the battery positive voltage circuit fuse is installed in less than 60 seconds .
Install the fuse.
Old Sep 27, 2011 | 09:40 PM
dan-t's Avatar
dan-t
thanks guys il try it all this weekend when i get a minute, you all are great help
Old Sep 27, 2011 | 10:25 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Did you see a B361 or B363 code(s)?
Old Sep 28, 2011 | 12:49 PM
dan-t's Avatar
dan-t
yes both in history codes
Old Sep 28, 2011 | 01:36 PM
dgrant3830's Avatar
dgrant3830
So, real simple...clear those codes and this will cause the system to recalibrate. If the code(s) come back, then you've probably got this in the picture:
Old Jan 1, 2015 | 03:40 PM
hdrider13's Avatar
hdrider13
5th Gear
I re-calibrated and it lasted a week, now cold air on drivers side again. Why does it not staying re-calibrated?
Old Jan 1, 2015 | 04:25 PM
209TIME!!!'s Avatar
209TIME!!!
Not trying to hijack this thread but maybe someone in this thread can help me also...I have a different issue, my heat and air both stopped working but i did not get any codes...if i turn my heat on full blast when its cold outside my windows will defrost and i can feel just a little bit of heat, other then that nothing. I don't know where to start with this issue. thanks for any help or advice
Old Jan 1, 2015 | 07:01 PM
frsr06's Avatar
frsr06
This thread is 3 years old...
Old Jan 1, 2015 | 09:32 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
This might or might not help you out - but it sounds like you might have an actuator out of sync - even though you are not experiencing any codes.
Here are a couple of write-ups that just might help out, plus you might even have the passenger side door or flap stuck with debris:
https://www.corvetteforum.com/forums/...actuators.html
Specific passenger side actuator problem and repair:
https://www.corvetteforum.com/forums/...-actuator.html
This post also has other links in it too:
Let me know if any of these shed some additional light on your situation
Thanks,Matt
To no heat on drivers side
