While slowly accelerating in first gear from a stop light today it popped out of gear I immediately put back in first with no problem. I hit three more lights on the way home and ran through all the gears with no problem. Other than this one time i have never had a problem, always shifts smooth. Anything to worry about or just a fluke thing? 99FRC W/68,000 miles.
Thanks for any thoughts on this.
Mine has done it a couple times while I was getting used to the car. It was definitely user error, 1st gear needs to be bullied in a little bit more than the other gears I've noticed.
You might of not had it in all the way, Just keep an eye on it.
Mr.Bill
It happened to me one time when I was still learning to drive stick. It was a very scary and unsettling noise and feel too when it popped out! Just make sure you are ALL the way up there in 1st.
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
I get reallt pissed off at myself when I let that happen every once in a while. I have a Ripper shifter,,,whenever it flies out of first,,,,it is MY FAULT! for not locking it in, in the first place!
