PLEASE HELP! I know this sounds dumb, but i can not get my stereo out. It should be simple, but when i got down to the last two screws( the one on each side of the face plate) they were not there,yet the stereo will not move. All i can figure out at this point is that the previous owner has modified it and has something else holding it in but cant see behind it so i have no idea how it is attached??? Does anyone have any ideas of what i should be looking for here????
Thanks for reading!
can you get it to tilt up or down at all? i doubt the last owner ran screws in from the side..that would be hard and nothing to mount into really..if i remember right my stock unit was wedged in there pretty well...i had to give a good tug to get it come out
You know what man, tomorrow i am going to give it a good tug!!!
I think you just might be right! I was scared to pull on it,afraid i would break something, but since you mentioned it , and i cant figure out anything else, cant see what it will hurt to try at this point!
Thanks so much for your time!
I will try to let you know if that was all it was.
Thanks for reading!
Well I hope he didn't do anything stupid like epoxy the tabs to the metal mounting frame... Look at the tabs where the 7mm bolts are supposed to go. Do you see any signs of adhesive?
Also, the poster above is right. The stock units do get wedged in there pretty snug. Pull the AC control unit out of the way and reach in there and give it a good tug... Feel to make sure the wiring harnesses and wires plugged into the back of it aren't caught on anything...
Also, where are you located? You should fill out your profile...
Thanks for the reply and advice! Gonna try it tomorrow.
And yes, i will be doing my profile real soon. I did not think i would use this forum much when i signed up, but with all the replys and great advice coming in to me from what seems to be some really cool people(of corse, what other kind of people own a Vette- right), i am really going to enjoy this forum!!!
Oh and i am going to clean her up over the weekend and post some pics of "THE BEAST" for you to check out (OF CORSE MY 17YR. OLD SON NAMED HER) aND I AM GOING TO YOUR PROFILE NOW TO CHECK OUT YOUR BABY!!! ---- THANKS AGAIN!!!
If I remember correctly there is a rubber pin on the stock head unit that is wedged into a hole on the brace in back of the radio. Just pull it with a little effort and it should pop right out.
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
There are some real fine folks in the Pensacola area. Post in the regional section and I bet you get a volunteer helper with stereo experience real quick.
DUDE,---- YOU HIT THE NAIL ON THE HEAD!!!!
I HAD TO WORK A FLAT HEAD UNDER THE FRONT BRACE WHERE THE SCREWS WERE SUPPOSED TO BE,WHILE AT THE SAME TIME TUGGING HARD ON IT, TO GET IT TO LET GO!
(I AM JUST GUESSING, BUT IT MUST HAVE BEEN THERE SO LONG IN THIS HUMID / FLORIDA HEAT,THAT IT KINDA MELTED/STUCK TO THE SURROUNDING CONSOLE MATERIAL????)
ANYWAY, YOU SURE SAVED ME A MIGRAIN!
OWE YOU ONE!!!!!!!!!!!!
A BIG THANKS TO YA!!!
iT DANG SURE TOOK SOME PRYING/PULLING, BUT YOU WERE RIGHT,IT WAS JUST STUCK!!!!!!!
HEY, THANKS AGAIN, MAYBE I CAN COME OF WITH AN ANSWER FOR YOU IN THE FUTURE!
THANKS TO YA, GOOOOOT ITTTTTT OOOUUUTTT!!!!!
AND W/O I HEADACHE, THATS TO U GUYS!!
duh??? WILL YOU PLEASE TELL ME HOW TO POST IN THE REGIONALS????? WOULD LOVE TO GET MORE HELP/GOT LOTS OF WORK TO DO AND ALOT OF QUESTIONS!!!( FIRST THING BEING--- RADIO PLAYS SOMETIMES AND SOMETIMES IT DONT??)--CD WORKS ALL THE TIME.
GONNA CHECK OUT THE ANTENNA ON WINDSHIELD TOMORROW. IT IS ON THE FRONT WINDOW ISN'T IT? OR IS IT ON THE REAR??? duh???
well i hope he didn't do anything stupid like epoxy the tabs to the metal mounting frame... Look at the tabs where the 7mm bolts are supposed to go. Do you see any signs of adhesive?
Also, the poster above is right. The stock units do get wedged in there pretty snug. Pull the ac control unit out of the way and reach in there and give it a good tug... Feel to make sure the wiring harnesses and wires plugged into the back of it aren't caught on anything...
well,now that the hu is out of the way, what would you think the problem with the hu radio not working about half the time? The cd works great all the time. Thought it might be the antenna cable coming loose but that was not it???
I'm in Milton neighbor, let me know if I can ever help. No electrical engineer here but I've found electrical contact cleaner is miracle stuff. If CD works then the problem could be in selector switch, I'd spray it down with contact cleaner. Does cycling radio switch multiple times help now?
Thanks to ya Neighbor!
I will get some of that contact cleaner over the weekend and try it and let you know.
Oh, by the way, can you tell me exactly where to spray it?
