Climate control
Old Sep 30, 2011 | 07:34 PM
828ayount's Avatar
828ayount
6th Gear
Default Climate control
how do you fix climate control on passenger side. It only blows out warm air
Last edited by 828ayount; Sep 30, 2011 at 07:35 PM. Reason: need an answer to a question
Old Sep 30, 2011 | 07:53 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
There are a couple of possibilities. Pull your codes from the DIC and post them as this will show if there's an actuator issue or not. After that, clear the codes if any from the HVAC and this will cause the system to recalibrate. If your HVAC operation comes back to normal, you are done. If not, pull the codes again and see if any HVAC codes came back. Please post those results. Another real possibility is that you are low on refrigerant but do the codes first. Lastly, do any of the other modes for air direction work? Is this a manual or Dual Zone automatic HVAC?
Old Sep 30, 2011 | 07:54 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Check the DIC for codes.
More than likely, you are a bit low on refrigerant.
Old Oct 1, 2011 | 07:06 AM
828ayount's Avatar
828ayount
6th Gear
Dual zone automatic
Old Oct 1, 2011 | 08:23 AM
Jeff in Den's Avatar
Jeff in Den
Sounds like you are going to find a right side actuator code. If you get cold air on the driver's side, but only hot on the passenger side, the actuator on the right hand side has or is failing and adding refrigerant won't help.
Old Oct 1, 2011 | 10:41 AM
jrose7004's Avatar
jrose7004
My old 98 did that when it needed a freon charge.
To Climate control
