243 Head and cam swap complete.
I have yet to have it dyno tuned, but a buddy of mine Matt ( aka madmatt9471) hooked me up with a tune from his HP tuners since the setup I have is close to a set up he once had a while ago.
We are estimating approximately 420 RWHP which is where I want to be. For now anyways. It's real easy to get bit by the power mods. If it turns out to be less, that's OK. I am happy with the results thus far.
Future plans included dyno tune, 3:42 rear gears, 2800-3000 stall converter and a couple other things. I can't say enough on how impressed I am with the changes. The car feels completely different. My 05 GTO that I recently sold didn't even come close to feeling this strong and responsive. I thought the GTO was fast, at least in stock form anyway.
Thank you for viewing and here are a few pics of the build.
420RWHP could be a lil optimistic? I don't know, that's why I'm asking.
I was told by a few reputable tuners that with a proper tune, 420 RWHP give or take is not uncommon for my setup. I can't wait to get her tuned just to confirm. If it's a little less, I still will be happy.
Thanks.
Thanks.
Yup still running the stock converter, for now anyway. I honestly thought the same as you. Around 380-390. I spoke with some of the reputable tuners here in Southern California and 420 was the number I got from them. Maybe they assumed I am running Long tube headers? I don't know. I gave them all the specs and also listed everything I have on the car. If I had to put money on it, I would have to agree with you, but if It turns out to be like they say, then I will be very happy. I'll make sure to post numbers once I get a proper tune.
also i cant remember where i saw this but in your case i read an article about using c6 zr1 manifolds over the zo6 ones. might be something to look into The Best of Corvette for Corvette Enthusiasts
Sorry I forgot to list the cam specs. Nothing to crazy. Smog friendly for CA. Comp cams 224/224 .564/.564 114 LSA.
My brother is in Northern California, so I know about the LT headers being a "no-no," although lots of guys he runs with have them up there. Some people honestly believe "shorties" are a waste of money, but that's not my comment. Hope everything turns out well on your upcoming work, My setup is similar to yours, except for a few changes, you can see what they are below:
==Stock Bottom, LS6 Heads 243-Gen-III, comp.cam (921) dual springs/titanium retainers, 7.400chm pro pushrods, LS6 Intake, 2004-Z06Cam, 160TS, LS2Timing chain, Ported LS6 oil pump, 25%UD Pulley, BlackWing, LG LT Street Headers, with Hi Flow Cats, X-Pipe, Z06-TI‘s, 3:15gears, 30lb-SVO Fuel Injectors. They say I have a conservative "tune," at 389RWHP, 383RWTQ.==
I did this work at probably 40k+ miles, I now have 80300 miles on it, a 00-C5 Coupe.
It's more near 380 - 400 RWHP, but the Dyno will tell and the 3.42's and Stall will really make it come alive
LT's will go a long way as well!
Thanks,Matt
420RW my be a reach though. I only got 417rw and that was with a bigger cam, LTs, catless X and underdrive on a Z06(less drivetrain loss). I would guess you'll be just a bit under 400rw, which shouldnt be disappointing at all
I know my setup is nothing new to most, but for those that have the same concerns as I did. This IMO is the way to go. Thanks again for the positive feedback.
Thanks again for your help! I really appreciate it brother!
Thanks, Jorge
Jorge
243 stock heads
LS6 intake
224/230 .581/.588 113 LSA
AR LT headers
Yank 2800 stall
3:42 gears
I netted 416 rwhp and 392 rwtq (Mustang Dyno)
FYI it freakin' screams.
