12 disc changer won't eject. any tips?
Old Oct 3, 2011 | 07:55 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default 12 disc changer won't eject. any tips?
other than replacing the factory stereo?
Old Oct 3, 2011 | 08:13 PM
Dixiecrat's Avatar
Dixiecrat
Do you mean when you push down it wont come up. You do know the 12 disc are in the rear ?
Old Oct 3, 2011 | 10:27 PM
904pizza's Avatar
904pizza
Buy mine that's sitting in my garage
Old Oct 3, 2011 | 10:41 PM
Markm10431's Avatar
Markm10431
Parrothead
exacty it will not eject. I think the number 1 disk is jammed or soething cause it tried to do something on that end of the changer when you open the door
Old Oct 3, 2011 | 11:47 PM
1BAV's Avatar
1BAV
Cruise-In IX Veteran
Seems to be a common problem. Same thing happened to mine a few months back. I took the thing completely apart to get it unjammed. I got it back together and it worked fine for about a week. There is a part inside, not sure what it's called, but it goes bad. I ended up buying one from a forum member. There are plenty of them on fleabay too. I looked into getting it repaired and decided it would be better just to find another one. I've been pleased with the replacement. Good luck.
To 12 disc changer won't eject. any tips?
