Cold air intake vs stock
Old Oct 4, 2011 | 11:32 AM
rebelheart's Avatar
rebelheart
Originally Posted by ztheusa
A "cold air" system delivers more dirt and the air isn't any colder. Also, everyone complains about reduced gas milage. If you want more air just take the filter out. Costs nothing and does the same thing as a "cold air" intake.
This is completely misguided and inaccurate!
Old Oct 4, 2011 | 11:41 AM
mcv's Avatar
mcv
Independent testing run in Vette Magazine.
Old Oct 4, 2011 | 11:43 AM
bucwheat's Avatar
bucwheat
Add that to a less restrictive exhaust system and you can gain rear wheel HP.
Old Oct 4, 2011 | 12:18 PM
hdkeno's Avatar
hdkeno
Then top it off with a good dyno tune
Old Oct 4, 2011 | 04:49 PM
Ryanmgaspard's Avatar
Ryanmgaspard
Cruising
Isn't the honker the same concept as the flip mod?
Old Oct 5, 2011 | 10:51 AM
Ryanmgaspard
Cruising
or same concept as "hillbilly honker" mod?
Old Oct 5, 2011 | 11:15 AM
mcv's Avatar
mcv
No, they are not the same.
Cold air access is only one of the advantages that the Honker system provides.
The C5 Honker relocates the MAF sensor and eliminates the over-radiator "air bridge". The shape of the air bridge, including high performance versions, causes diverging and converging air paths that ultimately restrict flow, when compared to the Honker shape in the same area.
Also, the shape of the Honker air box was computer-designed and fine-tuned on the flowbench for maximum airflow and minimum restriction.
Relocating the MAF sensor just in front of the throttle body, close-coupling the two components (as done by GM on C6), also demonstrated improved performance.
Manufacturing simplicity and cost control were not primary considerations in the Honker design process, as they may have been for the OEM parts.
Old Oct 5, 2011 | 07:41 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Vararam B2 cut 3/10th's off my 1/4 time all by itself. Way better TR as well.
OP, a good CAI will improve performance!
Old Oct 5, 2011 | 08:51 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
It is colder than the air in your engine bay.
Cold air intake on my car for a decade and no problems here.
Get over your fears you own a vette
