Roof Panel Fix
Old Oct 6, 2011 | 07:44 PM
Vic'sVette's Avatar
Vic'sVette
Default Roof Panel Fix
Previous owner introduced her into the flying roof panel club (I know what your thinking, but, no I did not do it... yet....) Tried to attach pics but for some reason posting rules says I cannot attach files. One side is just cracked and maybe epoxy will fix it. The other side has a small chunk missing and will have to be filled with something. Dude tried to fix it and repainted it with flat black paint. Is there any way to fix this??? I have other things I need to to before I drop the cash for a new one so if there is a way I can repair this for now I will do that and maybe get a targa next spring. Thanks. BTW. Corvette weekend in Eureka Springs Arkansas this weekend (did I just hijack my own tread???
Old Oct 6, 2011 | 07:55 PM
jrose7004's Avatar
jrose7004
Take it to a body shop. I bought one that had flew for the 98 coupe that I used to have and a body shop fixed it as good as new.
Old Oct 6, 2011 | 08:15 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Is it the acrylic top, or the hard top?
Here is what I did for the solid top...
http://forums.corvetteforum.com/c5-g...ga-repair.html
Old Oct 6, 2011 | 09:06 PM
Vic'sVette's Avatar
Vic'sVette
Thanx stalion. Nice fix. Its a hard top. I don't know if its made of plastic or fiberglass. I was not sure if I needed to use bondo or fiberglass resin to fix it or something else. Yeah jrose I may just end up taking it to a shop but was going to try & see if I could fix it myself. Thanx.
Old Oct 6, 2011 | 09:36 PM
LMFD296's Avatar
LMFD296
can you paint the acrylic tops? Im sure if you could you would need a ton of prepping?
Old Oct 6, 2011 | 10:03 PM
Yes, you can paint the lexan top. The procedure has been posted here on the forum a few times - however, if you're really interested and can't find it using the search, I have a Word file that details the process. If you'd like a copy, PM me your e-mail address.
To Roof Panel Fix
