[Z06] Help! I got critters...
Old Oct 8, 2011 | 06:57 PM
pql-lbc's Avatar
pql-lbc
Default Help! I got critters...
Chewing stuff up in my engine bay! Found the rat bastards have been munching on various things in both the Z06 and TT's engine area and building a cozy nest under the TT's engine cover. Any suggestions on ridding myself of these critters?
Old Oct 8, 2011 | 08:06 PM
hotwheels57's Avatar
hotwheels57
My solution wasn't inexpensive...put your car(s) six feet up on a lift. It works.
If you use search or search this forum (in the red banner) in C5 General, you should find plenty of past threads with home concoction ideas. Use keywords "rodents", "mice", "rats", or similar.
I recall suggestions of cats, IRISH SPRING soap, mouse traps of various designs, dryer softener cloths, moth *****.
Just passing on others suggestions with no guarantees that any of those will work...
Old Oct 8, 2011 | 08:37 PM
Woodytick's Avatar
Woodytick
get a cat!!!!!! problem solved!!!!
Old Oct 9, 2011 | 01:32 AM
LWSZ06's Avatar
LWSZ06
And don't feed it!
Larry
Old Oct 9, 2011 | 09:10 AM
91 monster Z's Avatar
91 monster Z
Go down to your local walmart or tractor supply and get some of the
green rodent bait. Than put next to the garage door opening and under any thing else they will come out under. Plus look around and plug up any hole in walls with foam sealant. That what I did when I had the same problem plus I got me a cat or two. Between all of that I have solved my problem with the pesty liltte things.
Old Oct 9, 2011 | 01:58 PM
budnate's Avatar
budnate
bad news for you....once they make a nest they put out a special urine...it marks the spot as home base...even if you kill them others will find the scent and move in......I had it happen to my dail driver ford ranger the intake area had a nice hole like a old mopar motor, raised plenum...warm motor..some firwall insulation ...nice home at night.....consulted with experts...cleaned with everything known to man...still had problems off and on...nothing like the smell of a hot motor and rat wizzzzzz. killed a few of them...more came.
simple green makes a super enzime cleaner that would kill the odor but the motor area had a weird musty smell after using it and sometimes came in with the heater on.......sold the truck.
Old Oct 9, 2011 | 09:32 PM
pql-lbc's Avatar
pql-lbc
Well...the rat bastards better start paying rent or else they will get what's coming. Laid out some Decon trays as well as some peanut-butter flavored glue trays. Let the hunt begin!!
Old Oct 10, 2011 | 12:10 AM
Zeus-of-Boost's Avatar
Zeus-of-Boost
yaaaa right lol
http://www.youtube.com/watch?v=DPK_i...eature=related
Old Oct 10, 2011 | 10:57 AM
pluslt's Avatar
pluslt
green rodent bait. Than put next to the garage door opening and under any thing else they will come out under. Plus look around and plug up any hole in walls with foam sealant. That what I did when I had the same problem plus I got me a cat or two. Between all of that I have solved my problem with the pesky things.
+1 on that. I had them in my shed and put that green bait out. It came in a box with 4 sealed trays. I placed them in the four corners of my shed and haven't seen a mouse or mouse turd in months. They gobbled up about half of one tray right away and some nibbles on the others. I think they've been wiped out.
Let the hunt begin. Good luck.
Old Oct 11, 2011 | 01:16 AM
pql-lbc's Avatar
pql-lbc
Nothing yet. Pesky rat-bastards.
Old Oct 11, 2011 | 01:17 PM
budnate's Avatar
budnate
some of these guys are pretty sharp to man scent...glove up, lay traps with peanut butter not set..feed them a day or 2 then set them...I have been running the T-Rex traps...check 'em out mean sobs....
Old Oct 11, 2011 | 06:59 PM
MotoJB's Avatar
MotoJB
I use traps and have gotten many rats...fortunately they haven't made a home in our cars.
Had a mouse die in our house heater vent this week though. Nasty! We were like WTF is that smell??
Old Oct 12, 2011 | 12:52 PM
dogboy's Avatar
dogboy
Read this as it happened awhile ago.
Default 77 is now officially a "RAT ROD"
Funny disgusting story that happened to me today. I get a call from my son that the 77 is leaking water somewhere and overheating. He is stuck about 2 miles from his work and called me for help. He shut it down when the temp gauge reached about 250 I told him to let it cool off for awhile and than see if he can make it to his parking lot and I will see the car when I get there. Its raining cats & dogs so I know its not gonna be fun. I pack some duct tape, 4 gallons of water, tool box ,stop leak, and head out. I find the car in the lot 1/2 hr later and proceed to check it out. The rain stopped at this point but the ground is a puddle so I know I will have to get a visual on the leak to find it. I pop the hood and start it up. After a minute I see it pissing water from the front seam of the drivers side radiator behind the headlamp area. As I'm looking at it I see this gray creature running under the fan shroud " Holly sheet its a rat that got into the engine bay. It was about 7-8 inches long not counting the tail. I start banging around the engine bay hoping to flush it out . (I think it came from the shrubs next to the car.) after a couple of minutes of letting it cool again I opened the rad cap and poured in some stop leak and 3 gallons of water. I let it run for a bit hoping that the leak will slow down enough for me to get the car back home so I can pull the rad out for a repair tomorrow. As I'm watching the leak to see if its slowing down I hear this knocking sound as if the fan belt was ready to snap, I see furry pieces shooting at me and as I jump back I hear "WHACK" and through the air at a good velocity I must say this freakin rat shoots past me and slams into the window of this SUV that was parked next to me and on the ground, dead as a doornail, is the rat!. There is now rat guts in my fan shroud , blood and guts on the SUV and a big dead rat lying next to the pass door. WTF I proceeded to close the hood and calmly drive away. I did make it home and the stop leak actually worked but I pulled the rad and washed off the guts from the engine bay. It is now christened the "Rat Rod".
dogboy is online now Report Post Edit/Delete Message
Old Oct 12, 2011 | 11:48 PM
pql-lbc's Avatar
pql-lbc
Awesome...However, from the pawprints I found around the engine bay, it won't be as big as your critter if/when I catch the rat bastard!
Old Oct 13, 2011 | 01:30 PM
bumble-z's Avatar
bumble-z
Word to the wise.
Forget bait & set real kill traps for rats & mice.
They like to take the bait & store it in the most peculiar places.
For instances, they can take it up into your muffler tips & store it & some times die in the mufflers. That is if your lucky.
It's best to see the critters dead & disposed of.
As far as rats, it's best to add a nail or screw to the wooden area of the rat trap & tether that to a wire to a heavy fixture.
Good luck.
To Help! I got critters...
