[Z06] National Corvette Museum Store
Old Oct 10, 2011 | 04:55 PM
NCM Store's Avatar
0NCM Store
Former Vendor
Default National Corvette Museum Store
We are the Corvette Store located inside the National Corvette Museum in Bowling Green, KY.
All things Vette!
You can contact us at storecustomercare@corvettemuseum.org or 800-53-VETTE. We look forward to hearing from you!
Check out our site - we cater to all generations!
(Click Image to see item on the website)
C5 Corvette Emblem Hooded Sweatshirt Sweatshirt features the C5 Corvette emblem on the front chest and C5 Corvette script printed down both sleeves. The 50/50 blend of cotton and polyester makes this Corvette sweatshirt pill resistant. The super soft fleece lining will keep you warm and comfortable. The hood is double lined and the front pocket is roomy enough for gloves and keys. $49.00
C5 Corvette Battery Charger Connection System Push/pull quick connect battery charger connection system means no more cords routed through open hatches, hoods, or windows. Additionally, there's no interference with car covers, reduced vulnerability to scratches, no more access points for pests or rodents to enter, and it's easy to install!
An aviation grade "push/pull" connector/receptacle mounted to a vehicle specific, custom designed bracket is the key to construction. The receptacle/bracket assembly is fitted with the appropriate length wire and secured to the vehicle. The negative wire is routed to a chassis ground and the positive wire is fitted with inline fuse protection and attached directly to the battery. The connector is fitted to either an SAE or Ctek cord that attaches to your battery maintainer. You now have the ability to "park-n-plug".
With the new "Remove Before Flight" window reminder, you no longer have to be concerned with vehicle movement while your charger is still connected. Just stick the tag on your window to remind yourself to disconnect. $80.00
C5 Corvette Ladies' Denim Jacket Stylish dark denim Lee® jacket features a button front, button pockets on the chest, two front slash pockets, contrasting stitching and a sparkling rhinestone C5 emblem on the back. 99% cotton, 1% spandex. $72.00
To see more, click here.
