Removed BSM gone bad.
Old Oct 12, 2011 | 10:26 PM
mountainbiker2's Avatar
mountainbiker2
Default Removed BSM gone bad.
** Update** post #13
I removed my BSM and put marks down the whole side of the door. I used weed eater line that was shape like a hexagon. What I thought was glue marks left over, was actually paint that came off. I'm no waxer, but this is definitely going to be a problem to fix. If I used fishing line, maybe this wouldn't have happened. Don't know.
Steve A.
Old Oct 12, 2011 | 10:30 PM
atmsrus1's Avatar
atmsrus1
Yea fishing line would have been your best bet. May want to post up in the detailing section, those guys can probably help you make it look a lot better
Old Oct 12, 2011 | 10:45 PM
X-Ravin's Avatar
X-Ravin
Some of the lighter scrapes can be polished out, but the ones that removed paint will need to be touched up and wet sanded
Old Oct 12, 2011 | 10:51 PM
jrose7004's Avatar
jrose7004
I am glad that both the C5's that I've had didn't have BSM's! Sorry for your problem.
Old Oct 12, 2011 | 11:09 PM
zesstey1's Avatar
zesstey1
Bummer!
Old Oct 13, 2011 | 12:52 AM
ronssito's Avatar
ronssito
I removed the hideous things from both my cars with no problem.
... a helper, heatgun, fishing line and patience.
...... it's just a car and can be fixed.
Old Oct 13, 2011 | 01:57 AM
GBsC5Vert's Avatar
GBsC5Vert
From: LA/OC border, probably sittin' under the patio, by the pool...smokin' a cigar! SoCal
I just removed mine this past weekend. I too was worried what I would find, but all went well, no damage. I used a heat gun, a bit of 100lb fishing line to start the edge, and once the edge was up, grabbed the lifted end, heating/lifting till removed.
Sorry to see this happen to you. Like posted above, a little touch up paint. some wet sanding, polish, and you should be good.
Is that Sebring Silver? That's what I have. I have a SS front end that is damaged. I can cut a piece off and mail it to you if you want to practice. That's what I do.
Old Oct 13, 2011 | 06:58 AM
guido7834's Avatar
guido7834
See, you should have left them, since they look better anyway!
Good luck with the touch up.
Old Oct 13, 2011 | 07:43 AM
Too bad you had the problems - hope you can get the paint fixed without a major expense.
Old Oct 13, 2011 | 07:51 AM
fendermender's Avatar
fendermender
I'm familiar with that trimmer line and it's way too thick for taking mouldings off. Plus the hex shape gives it sharp edges. It is made to cut after all. In addition to fishing line, I have had success with mig welding wire.
I hate to say this but the only way that will look right is with a respray. A good paint person should be able to blend it.
Old Oct 13, 2011 | 09:45 AM
Dominic Toretto's Avatar
Dominic Toretto
Sorry for the bad luck
-Alex
Old Oct 13, 2011 | 06:33 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
well maybe if you put them back on it will cover the damage....could be cheapest way out.
Old Oct 13, 2011 | 07:44 PM
mountainbiker2
**Update**
It turns out that the moulding covers up all the damage. I originally thought the scratches were wider then the moulding. I put the door ones back on. I still have to put on the ones right behind the vent. Thanks for the help.
Steve A.
Old Oct 13, 2011 | 07:45 PM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
Even with the scratches, it still looks better than with the BSM on there.
A little touch up paint and only you'll know it ever happened.
Old Oct 13, 2011 | 08:32 PM
ROJ#79's Avatar
ROJ#79
They were put on my car for a reason. I see no need to remove them!
Old Oct 13, 2011 | 08:35 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Steve, Steve it looks better with them on - when will you all learn
Thanks,Matt
Old Oct 13, 2011 | 08:37 PM
HotrodZ06's Avatar
HotrodZ06
Hey Steve,
The BSM's are not that heavy! How much weight have you taken off of your car already?
See you this weekend at El Toro.
Rod
To Removed BSM gone bad.
Old Oct 13, 2011 | 08:58 PM
Jet-Jock's Avatar
Jet-Jock
The other side was damaged too?
Old Oct 13, 2011 | 09:22 PM
mountainbiker2
I damaged both sides. I was taking them off in the dark. I didn't realize what a butcher job I was doing. Both of them weigh 1lb 11oz.
Old Oct 13, 2011 | 09:31 PM
Jet-Jock's Avatar
Jet-Jock
Sorry to hear that.
So you removed the old tape and applied new tape to the BSM and re-installed it?
