Winter Storage
Old Oct 17, 2011 | 10:37 PM
murf257's Avatar
murf257
Default Winter Storage
Those of us who live where the snow will be flying soon need to store their cars for the winter. What do you do to winterize your car? Anyone here of some chemically treated garage floor mats that are chemically treated to prevent dryrot?
Old Oct 17, 2011 | 11:57 PM
itzza427's Avatar
itzza427
Change the oil,,add some fuel stabilizer,, add a few extra pounds of air and hook up a battery tender and you're good to go. Take it out for a good drive whenever the snow is off the road,,and get the oil temp fully warmed up and drive her for a while. I drive mine pretty regularly all winter,,only letting her sit out the nasty stuff. Lots more fun than just sitting there thinking about it!!!
Old Oct 18, 2011 | 06:11 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I change the oil, add fuel stabilizer, over inflate my tires, and disconnect the negative battery terminal. (I've stored my car for 11-years using this method and it always fires right up in the spring.) I also put about 10 bars of Irish Spring soap in the interior to keep the mice away. I've never had a problem with the fury little critters and my car smells shower fresh in the spring.
Old Oct 18, 2011 | 06:59 AM
219fit's Avatar
219fit
Nobody puts there car on jackstands and store wheels/tires inside? It's what I've done in the past.
Old Oct 18, 2011 | 07:09 AM
Must_Have_Z's Avatar
Must_Have_Z
Nope. Really no need for it today. Tires are much better quality, and your suspension will be just fine... I simply drive my Z onto some thick mats to keep the tires off the cold floor, but even that's overkill.
Old Oct 18, 2011 | 08:29 AM
Baibaikin's Avatar
Baibaikin
Anyone had fuel gunk up because they didn't add stabil?
Old Oct 18, 2011 | 08:41 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
On both of mine ,I just use fuel stabiliser in the tanks and a C-tEK charger , close the door and in the spring light them up and go. I don't see the point on changing oil or put it on jack stands or inflate the tires. Really if you think of what car dealers do to cars that are sitting on the lots before you buy them, they do nothing and cars sit there for weeks and months . All a big mith, Ron
Old Oct 18, 2011 | 08:53 AM
tomringo's Avatar
tomringo
From: Richmond VA Everyone should have a VetteGuard
Wash, some wax, change the oil, gas stabilizer, extra air in the tires, put down a big sheet of plastic on the floor tape down the egdes and park it on some nice carpet squares I got at Wally World (overkill but makes me feel good) dryer sheets around inside and put on the tender, cover it it up and wait for spring
Old Oct 18, 2011 | 09:17 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Old Oct 18, 2011 | 09:11 PM
murf257's Avatar
murf257
I have had a lot of replies stating how well the dryer sheets work in keeping insects and rodents away!
Does anyone know about the pads to place under the tires to prevent damage????
Old Oct 18, 2011 | 10:13 PM
Coal is King's Avatar
Coal is King
I parked mine last year on a tarp and placed 1" thick insulation board cut 2'x2' under each tire, maybe unnecessary but made me feel better. As others have said I over inflated tires, dryer sheets under hood and in exhaust tips as well as scattered around exterior, Irish spring and baking soda in cabin, removed battery (no heat in storage unit), Sta-bill in a full tank of gas, and finally put a cover on her. Fired right up this past spring. A forum member (vetteman jack) sent me a word doc last year with storage info, if you provide me your email I can send it to you. By the way I am pretty sure I had one of the best smelling storage units on the east coast, this according to my unit neighbors.
Old Oct 18, 2011 | 11:17 PM
Here's what I do:
- Thoroughly detail car, inside and out.
- Put down some old carpet squares under each tire.
- Add Sta-Bil to gas tank and fill up with gas.
- Add a few pounds of air in tires.
- Connect Battery Tender Plus to battery.
- Change oil and filter.
- Put car cover over car.
- Wait for spring.
Old Oct 19, 2011 | 11:29 AM
garage-ghost's Avatar
garage-ghost
Best method I've found for unheated garage storage. The Car Jacket or Car Bag.
The car comes out in the spring, just like the day you put it away. The rotors aren't even rusty.
Note: Never cover or wrap a car with anything plastic or something that doesn't breath...unless you use desiccant. You will ruin your car. You have to use desiccant to suck up any moisture when using plastic. I use the 10# can that is good for two years of storage.
Old Oct 19, 2011 | 11:45 AM
ljorges's Avatar
ljorges
Sigh...why did you have to remind me!!!
Les
Old Oct 19, 2011 | 12:01 PM
phinfan's Avatar
phinfan
This is good info, would you mind telling me where you get this 10lb can of desiccant, what it is called, and do you just put it on the floor of the car?
Old Oct 19, 2011 | 01:27 PM
garage-ghost
The company that sells the bags, ( carbag.com), also carries the desiccant. I just put it inside the bag in the front or on one side of the car not inside the car. I try to put it somewhere I won't miss it when getting the car out in the spring. I have run it over. I also do the normal things like add air to the tires, fuel stabilizer, battery tender, dryer sheets. But I have to say after 30+ years of storing cars this is the best method I have found for an unheated garage and I have tried most of them.
To Winter Storage
