Driver Seat Memory problems
Old Oct 21, 2011 | 10:28 AM
SavPrato's Avatar
SavPrato
Default Driver Seat Memory problems
My C5 is no longer able to correcly remember my saved driver seat position. Every time I get into the car, it randomly selects a new seating position and this is driving me off of the wall to correct EVERY time. How do I disable the memory but keep the seating position controls active? Is there a fuse to be pulled for this?
Old Oct 21, 2011 | 10:38 AM
cuspid's Avatar
cuspid
mine hasn't worked right either. i press the button , it wil go to a position. Press it again it will creep further forward, press again it will creep forward again. Just don't use it at all
Old Oct 21, 2011 | 10:51 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Usually the seat connectors is the problem here. You might want to check them for worn out or lose pins/sockets.
Old Oct 21, 2011 | 12:31 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Originally Posted by 8VETTE7
Car battery is low.
that is one of the most common causes.
Old Oct 26, 2011 | 11:53 AM
SavPrato's Avatar
SavPrato
I suspect that it is a low battery issue. The battery is original (2003). I will replace it after I take it out of winter storage.
Thanks for all of your help guys.
To Driver Seat Memory problems
