Rear Partition
Oct 21, 2011 | 07:40 PM
Oldtimer
Rear Partition
My Z has a partition between the cabin and trunk. Is that removable? Seems like there is some velcro on the bottom. It also has an oval plastic 'window' about 10" wide, I have no idea what it's for...cant see it from the trunk side.
Oct 21, 2011 | 08:03 PM
Yes, it should just pull right out. It's an aftermarket part.
Oct 21, 2011 | 08:05 PM
Oldtimer
Quote:
Originally Posted by
RaW Z06
Any 'tricks' or tips to avoid breaking something?
Oct 21, 2011 | 08:16 PM
Open the trunk and start pushing it toward the front seats from the bottom of the partition. Once you get the bottom moving forward, you will be able to push top side forward on the driver side and then just pull it out through the door
Oct 21, 2011 | 09:01 PM
St. Jude Donor '10
Remove the velcro and pull it out through the passenger compartment.
However, the partition makes a HUGE difference in the amount of noise coming from the rear. It also makes the stereo sound better and the A/C work faster.
Oct 21, 2011 | 09:31 PM
A partition is a must for the FRC ... huge noise reduction. I've had 'em in both my cars.
Oct 21, 2011 | 09:57 PM
Oldtimer
ronssito
WHOAAA Boys!!! I only want to remove it to fix that plastic panel. P/O must have tried to wipe it with a solvent that smeared the plastic surface.
Oct 21, 2011 | 10:03 PM
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Whew!! We thought you were going to throw it away or something like that. You gotta have a partition, all the cool kids do.
Oct 21, 2011 | 10:16 PM
St. Jude Donor '08-'11-'12
^^^ All the cool kids do
Sounds like you might have an "Andy's Partition". Those are nice
Oct 22, 2011 | 12:19 AM
Oldtimer
Xx_Black-out
I think it might be!!
