Seat Memory
Old Oct 25, 2011 | 04:32 PM
smokjump's Avatar
smokjump
2nd Gear
Default Seat Memory
New owner of 2004 convertible. So far just a few bumps looking for help with. One is the seat memory "forgets". Set both to our specs but gone when we try it again. Common problem??
Old Oct 25, 2011 | 04:38 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
It must be enabled via the DIC buttons "options". Another thing is if you start the car with the door open it will forget. Sometimes on mine it has alzhiemers about moving but if I push the button it goes to the preset I had.
Old Oct 25, 2011 | 04:41 PM
WARD473's Avatar
WARD473
Same with mine.
Old Oct 25, 2011 | 05:16 PM
FKING1's Avatar
FKING1
Mine has amnesia too. Found that if you lock the car with the remote , then open with it the memory is retained (most of the time).
Sometimes when removing the key the seat goes all the way forward squeezing me into the steering wheel. Crazy seat!!!
Old Oct 25, 2011 | 10:02 PM
tsbbzm's Avatar
tsbbzm
And I thought it was just ME!!!
Old Oct 25, 2011 | 10:19 PM
MilleniumVette's Avatar
MilleniumVette
2024 C5 of the Year Finalist - Unmodified
Mine should be called "seat dementia". It does everything BUT retain it's memory unless I hit the recall button.
Old Oct 25, 2011 | 10:27 PM
VETJAZZ's Avatar
VETJAZZ
Very happy to know I'm not alone! I'm going to stop worrying about it.
Old Oct 25, 2011 | 10:35 PM
Last 62's Avatar
Last 62
I am in control of almost everything else, but the memory seat has put me in my place.
It works most of the time, then just to let you know who's boss, it will go about half way. I think I can hear it laughing.
Does anyone have one that actually works the way it should?
Jim
Old Oct 25, 2011 | 11:18 PM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
My seat memory works about 75% of the time.
Old Oct 26, 2011 | 12:18 AM
cedrop's Avatar
cedrop
Same problem with my 03.
There is comfort in numbers.
Old Oct 26, 2011 | 12:50 AM
alankb's Avatar
alankb
Default Ok
Seat is fine...Had to fix the mirrors, but the telescopic wheel does whatever it wants!!!
AL
Old Oct 26, 2011 | 08:05 AM
Praetorian27's Avatar
Praetorian27
I set my memory settings, but when I shut the car off nothing moves. The seller said that when you shut the car off, the steering wheel, and seat are supposed to move to give you more room for getting out. I get everything where I want it, and push and hold the memory button until it flashes. Am I doing something wrong?
Old Oct 26, 2011 | 09:46 AM
Burgie's Avatar
Burgie
I have found that memory dementia occurs when the car has been sitting for several days and there is a slight voltage drop in the battery. Once up and running at full charge, everything appears to work fine. Let the voltage drop a little and the gremlins start to show up with AC temp pre-settings, steering retract and the like. I'm starting to keep a trickle charger on it if it is going to sit for a week or so.
Old Oct 26, 2011 | 12:11 PM
pluslt's Avatar
pluslt
Jim
Hmm. Sounds like my wife.
Old Oct 26, 2011 | 08:03 PM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
Pretty sure there's something in the DIC options to make the seat move all the way back when you shut the key off. Mine does...most of the time. Don't think my steering wheel ever moved like that.
Old Oct 26, 2011 | 09:46 PM
C5FORFUN2's Avatar
C5FORFUN2
Mine always worked perfectly, put the key in, the steering comes back and seat goes forward. Shut it off and pull the key seat goes back and steering goes forward. If you don't unlock the door with the FOB then you need to push the setting # button on the door to activate the memory setting. I enjoyed the memory setting for about 4 or 5 years and then turned it off to save the motors.(and because I have the seat almost all the way back when driving and it's easy to get in and out of without moving anything)
Old Oct 26, 2011 | 09:48 PM
Praetorian27
Ooh...that's a good point! I never thought about the extra wear and tear on the motors!
To Seat Memory
Old Oct 26, 2011 | 09:51 PM
92GA's Avatar
92GA
Oldtimer
You have to have easy entry enabled for it to work. I shut mine off, so it wouldn't wear out the motors.
Old Oct 26, 2011 | 09:52 PM
o2bnkc's Avatar
o2bnkc
Are you pulling the key out? It has to be pulled out of the ignition first. Is the the easy entry set to "on" on your DIC?
Old Oct 26, 2011 | 10:24 PM
Praetorian27
I guess it wasn't. Good point made though about saving the motors!
