Tire Size Choice
Old Oct 30, 2011 | 02:04 PM
Mickeyrx70's Avatar
Mickeyrx70
Default Tire Size Choice
I recently bought my 1st Corvette, an '02 Coupe with Cray Scorpions (18x9 & 19x10.5). It needs tires. Currently it has 275/35/ZR18s & 305/30/ZR19s. I was considering a narrower tire, likely 245/40/18s & 285/35/19s. What are the pros/cons for the narrower tire versus the current size I have?? I'm interested in ride differences, primarily road noise and handling. Am I OK with the narrower tire or should I stick with the size I now have? I appreciate your sharing your experience. Thanks!
Old Nov 1, 2011 | 01:04 AM
had2have-it's Avatar
had2have-it
The bump to the next size in aspect ratio will help give you a bit more "tire suspension", improving slightly ride quality. Going to a slightly narrower tire will also help to lessen jolts and noise. I think you are going with the right sizes.
