[Z06] Horn stuck
Old Nov 5, 2011 | 02:09 PM
RJB34's Avatar
RJB34
Default Horn stuck
It might be a simple fix but I'm not mechanically inclined. I have a 2004 Z06. My horn stopped working, the fuse was blown and easy to remove. When I put the new fuse in, the horn started blowing immediatley. I pulled the fuse back out and turn off the alarm system. I put the fuse back in and the horn started again. I pulled the fuse again and this time I applied pressure to horn button on the column, I could here the switch clicking so I assumed it was working. I put the fuse back in and it was fine. I then closed the hood and the horn starting blowing again. I hit the horn switch a couple times and it was fine. Do I need to replace the horn switch? Any ideas?
Old Nov 5, 2011 | 02:35 PM
tlove32's Avatar
tlove32
http://forums.corvetteforum.com/c5-t...brane-fix.html
Old Nov 5, 2011 | 06:40 PM
Richard Thomas's Avatar
Richard Thomas
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
And this video gives some great pointers.
http://www.youtube.com/watch?v=9xGQWjxLZ3s
I did mine. Easy to do. I did lose my torx bit inside the steering wheel prior to its removal which was highly frustrating. Went to autozone and picked up a torx set that was self contained like a swiss army knife. Much easier that fighting with a bit.
The membrane I think is $60 from a few vendors.
Richard
To Horn stuck
