[Z06] Powershifter's time 11.90 time slip
Old May 6, 2002 | 08:15 PM
snide's Avatar
snide
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07 thru '11
Default Powershifter's time 11.90 time slip
:cheers:
Old May 6, 2002 | 08:37 PM
BigBlockChevy's Avatar
BigBlockChevy
Default Re: Powershifter's time 11.90 time slip (snide)
1.7 60', is that on slicks? excellent time :cheers:
Old May 6, 2002 | 08:45 PM
Power Shifter's Avatar
Power Shifter
Snide, Thanks for posting the slip, and thanks to Afy for getting my scanner working. BB, The time was run on 315 BFG's mounted on Z06 front wheels. My "mods" are a K&N replacement filter,160 T/S, manual fan switch,TBB,Ripper. The wheather conditions at NED were T=72deg RH=22% BP=30.07 inHg DA= 680'. Ric
Old May 6, 2002 | 09:04 PM
NoMercy's Avatar
NoMercy
Default Re: Powershifter's time 11.90 time slip (Power Shifter)
Power Shifter is one driving sumbatch!! :cheers:
Old May 7, 2002 | 01:03 AM
JoeyC5's Avatar
JoeyC5
Default Re: Powershifter's time 11.90 time slip (NoMercy)
Old May 7, 2002 | 10:29 AM
SmokieTheZ's Avatar
SmokieTheZ
Great run! :cheers:
...like that R/T too.
Old May 7, 2002 | 10:46 AM
dbvettez06's Avatar
dbvettez06
Default Re: Powershifter's time 11.90 time slip (BigBlockChevy)
PS that is some fantastick driving....Some great technique :cheers:
Old May 7, 2002 | 10:54 AM
BillY2KFRC's Avatar
BillY2KFRC
First, Congrats on that run, awesome driving! :cheers: Second, how well do the 315s fit on the 9.5" Z06 rim? Do you think you're getting the full contact patch that you would get with an 11" rim?
Old May 7, 2002 | 12:58 PM
YO-EL's Avatar
YO-EL
Default Re: Powershifter's time 11.90 time slip (BillY2KFRC)
Yes, I am curious to know as well as I am considering either 315/35 on 17x11 rims or 275/40 on 17x9 .5 rims.
What do you think?
Old May 7, 2002 | 01:50 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: Powershifter's time 11.90 time slip (indypace78)
Congrats on the great driving and awesome times.
Old May 7, 2002 | 06:35 PM
Power Shifter
Default Re: Powershifter's time 11.90 time slip (rschiltz)
Take a look in the Drag Raceing section, Scorp posted pictures of the 315's mounted on my Z06 wheels. I had to run higher air presure to get the center of the tire down to get the full contact patch. Thay seem to work well but if your not interested in haveing matching wheels an 11" wheel will be better. I don't know how much better. I do know puting more air in the 315 on a 9 1/2 worked better for me than a 275 on the 9 1/2 wheel. Ric
To Powershifter's time 11.90 time slip
