Something looks off.
Old Nov 16, 2011 | 01:02 AM
onspeed's Avatar
onspeed
Default Something looks off.
or is it just me?
Was trying to figure out why my stealthbox wasn't seating properly. Now I know.
Old Nov 16, 2011 | 08:05 AM
JerzeyJoe's Avatar
JerzeyJoe
Looks a little smashed up. That sucks. How bad is the damage?
Old Nov 16, 2011 | 08:29 AM
Daddyrama31's Avatar
Daddyrama31
Looks like your tub is cracked. The repair on the rear accident damage was not done correctly. Do you have the body shop info on who did the work?
Old Nov 16, 2011 | 08:39 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Car has been hit for sure.
The tub not only looks cracked, but buckled up as well.
I would have the car looked at by a body shop to make sure you have no frame damage.
Did you ever pull a Carfax on the car before you bought it ?
Old Nov 16, 2011 | 08:58 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Has it "EVER" been in an accident that you know of?
Perhaps the previous owner - looks like a new tub is needed or some reinforcement!
Any rear tracking problems for the rear tires? Unusual wear etc?
Thanks,Matt
Old Nov 16, 2011 | 09:13 AM
jrose7004's Avatar
jrose7004
Definately been hit hard.
Old Nov 16, 2011 | 10:55 AM
onspeed's Avatar
onspeed
I've known the car was in some sort of rear collision. Passenger side well has a bit of cracking. I think the frame (if damaged) was fixed. Car drives straight, and there were no issues when getting a wheel alignment. No irregularities in driving behavior that I can tell. Only thing is the occasional creak I hear from the rear when going up inclines.. I always dismissed it as suspension creak, but I'm thinking it could be the fiberglass. Visually, the body panels all look fine too. Except the trunk lid, and I know why now.
I'll probably get it fixed eventually. If I'm not mistaken, it's very labor intensive ($$$) to replace a rear tub.
Old Nov 16, 2011 | 11:27 AM
Does look a little beat up.
Old Nov 17, 2011 | 07:43 AM
WvCorvette's Avatar
WvCorvette
Old Nov 17, 2011 | 05:36 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Originally Posted by onspeed
I've known the car was in some sort of rear collision. .
looks like it was hit pretty hard from that picture. certainly enough to buckle the tub (which requires a pretty good shot from the rear). have you ever had the car on a lift to really inspect it closely?? is the wheelbase the same on both sides?? just another opinion, but it certainly looks like someone cheaped out on the original repair and made a cosmetic repair at the sake of a structural one.
Old Nov 17, 2011 | 11:17 PM
madmatt9471
Here you go:
http://www.ebay.com/itm/97-04-Corvet...d#ht_500wt_969
Thanks,Matt
Old Nov 18, 2011 | 01:34 AM
onspeed's Avatar
onspeed
Next time I have the car jacked up, I'll take some measurements to see if anything is obviously amiss. I don't remember seeing anything strange when I was swaping out axleback. I think it was hit in the right rear corner, just based on the damage to the rear tub. Plus the Borla Stingers I took off had a nice dent on the passenger side muffler, as well as a hole right where it goes over the axle... as if the CV joint had hit it or something.
To Something looks off.
