Cannot clear " Pull key, wait 10 seconds ".
Old Nov 17, 2011 | 04:40 PM
Alludc's Avatar
Alludc
Default Cannot clear " Pull key, wait 10 seconds ".
ok, so ive read everything to read here about the column lock issue and the pull key wait 10 sec DIC. my column lock fix was done prior to me buying the car by the dealer last yr. ive verified that. I had HP Tuners buddy turn off the fuel cutoff at 1.5mph setting and clear the code. Unfortunately both the service column lock and the pull key messages remain regardless of if I reset the battery...or pull fuse 23, or fuse 25, or do the reset of codes in the DIC the way its described in the sticky.. it always comes right back
05/11/2006
641007
ZFAT----Field Action Recall
V1409 - 04006 - Install Wire Kit Only - U.S. Manuals
38,405 MI
06/27/2002
666292
V0743 - ECL RELAY HARNESS REPLACE
18,531 MI
Product Safety Recall
N040006
04006
ELECTRONIC COLUMN LOCK SYSTEM
04/19/2004
Open
Customer Satisfaction Program
N010044
01044
CORVETTE ELECTRONIC COLUMN LOCK
07/10/2001
Closed
Old Nov 17, 2011 | 08:36 PM
Alludc's Avatar
Alludc
no new suggestions...? I hate the thought of going to GM.
Old Nov 17, 2011 | 08:40 PM
BOUT X's Avatar
BOUT X
Corvette Cowboy
this is going to cost you around 600.00 to fix I have 2 friends with this issue in the last 2 months if you want call RICHIE at Abel Chev. in Rio Vista here is his number 1-707-374-6317 and he will let you know what to replace he just did to of these at his Dealership
Old Nov 17, 2011 | 08:42 PM
Alludc's Avatar
Alludc
you lost me at 600. I can live with a DIC display that isnt effecting anything else.
To Cannot clear " Pull key, wait 10 seconds ".
