Need some help from the audio experts....
Old Nov 20, 2011 | 03:57 PM
FLYNAVY30's Avatar
FLYNAVY30
Originally Posted by 8VETTE7
Have you contacted Dennis and asked for his input on this problem?
yes he suggested the signal amplifier, which Ill probably try, Ive just heard mixed things about them and wanted to get some other people's input
Old Nov 20, 2011 | 03:59 PM
FLYNAVY30's Avatar
FLYNAVY30
Originally Posted by $$$frumnuttin'
best to 'move' this thread to the audio section...
yea, I was hoping that by posting here, I would get more traffic from someone else who had done the DD upgrade and dealt with the same problem
Old Nov 20, 2011 | 04:34 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Just a thought here. I have read on other forums that even though you don't have a power antenna the power wire still needs to be hooked up so that power is supplied to the antenna. I know, doesn't make a lot of sense if you don't have a power antenna but I've read that on numerous sites and from them it seemed to work.
try this, hook up the blue wires. On your harness from the radio there should be a blue wire and a blue wire from the harness that hooks to your factory wire. Most people don't hook those wires up if they don't have a power antenna, but I've read they are still supposed to be hooked up because it sends power to the fm amp built into radios.
If it's not that, and your antenna is hooked properly, you have a bum radio. The seperate amp you were talking about may work, but you still won;t have the greatest reception.
Those things were first designed back in the day to just bring in distant radio stations when we didn't have many fm stations around. But you could try it and see what happens as inexpensive as they are, if it doesn't work, take it back.
Old Nov 20, 2011 | 04:38 PM
FLYNAVY30's Avatar
FLYNAVY30
interesting...Ill give it a shot....working on the car right now....
Old Nov 20, 2011 | 05:02 PM
RetiredSFC 97
If that doesn't work try the booster. If it doesn't work you can always take it back.
Most car manufacturers now use a booster for the antennas that are in the windshield so the blue wires have to be hooked up for power. So with that said the booster may be your only solution.
I've never really seen any after market radios that had the same quality reception as a stocker, most noticeably so in newer cars.
Old Nov 20, 2011 | 05:34 PM
RetiredSFC 97
Here's a thread that talks some about it. Most of these threads are referencing the coupe which has a different system than we do. But from reading through some of these it may be a green wire you're looking for, if you aren't using an aftermarket wiring harness.
I have an alpine so the colors may be different for your pioneer.
http://forums.corvetteforum.com/audi...n-problem.html
