[Z06] Tire Question
Old May 7, 2002 | 10:02 AM
Z06Joe@AutoBuffs's Avatar
0Z06Joe@AutoBuffs
Former Vendor
St. Jude Donor '08-'09-'10
Default Tire Question
Does anyone know if it is a good idea to rotate your tires side to side? I know you can not go front to back, but I was wondering if I could go side to side, or if I should just forget about it and just ride till I need new tires. Thanks.
:seeya
Old May 7, 2002 | 10:20 AM
jerryv's Avatar
jerryv
Default Re: Tire Question (Z06Joe)
The tires are directional. No rotation.
Old May 7, 2002 | 10:28 AM
0Z06Joe@AutoBuffs
Former Vendor
Default Re: Tire Question (Jerry Velders)
I thought so, but I just wanted to make sure. Thanks
:cheers:
Old May 11, 2002 | 12:32 PM
MY 2002 Z06's Avatar
MY 2002 Z06
Z06 Tires are NOT directional. You may rotate them from side to side if you wish. If they were directional, then when you went to replace, you would need to buy 4 individual tires, because there is definately a mounting out side. "SIDE FACING OUTWARDS".
If you go look at your tires now (assuming they are still the F1 Supercar tires), you can see that one side is reversed from the other since they are identical tires. The tread pattern reverses from the left to right sides. Only requirement is to keep the large tread blocks on the outboard side of the wheel, therefore the "SIDE FACING OUTWARDS" on the sidewall.
[Modified by MY 2002 Z06, 4:44 PM 5/11/2002]
[Modified by MY 2002 Z06, 4:46 PM 5/11/2002]
Old May 11, 2002 | 03:16 PM
Dreamin's Avatar
Dreamin
Default Re: Tire Question (MY 2002 Z06)
Just follow what's written on the sidewall "Side facing outwards"... (which menas rotation side-to-side is ok)
To Tire Question
