Garage Heater
Old Nov 23, 2011 | 10:15 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Oil filled electric radiator heater is safe and keeps my garage above 50 all winter long on the low setting. My garage door is insulated but no other insulation on my 22x30 attached garage. On high setting and one other radiant heater I can get my garage to the low 70's in a few hours even when outside temps are in the high teens/low 20's.
Old Nov 23, 2011 | 10:53 PM
Too-Fast's Avatar
Too-Fast
Active Streak: 90 Days
2024 C6 of the Year Winner - Modified
Mine is about 1000 sq ft with a 10' ceiling. I use a 10,000 watt Qmark electric ceiling heater with a 650 cfm fan built in. The garage has R39 up top and R19 in the walls and is drywalled. I am at 7600 ft in Colorado and it does the job fine.
Old Nov 23, 2011 | 11:45 PM
RJMC5's Avatar
RJMC5
This what I have in my 1100 sq. ft. 14' ceiling garage. Works well, warms up quick, and has an electric igniter. I also have a couple of ceiling fans that help circulate the air. A well insulated garage makes a big difference.
http://www.northerntool.com/shop/too...6363_200316363
Old Nov 23, 2011 | 11:47 PM
jgump's Avatar
jgump
Get a 75K btu Mr. Heater (forced air) from Lowes. They have them in stock now and you do not have to pay shipping. Also, order the moving coupon and save and additional 10%. With a 9 ft ceiling you may even be able to use a 45K. I have the 75K with 12ft ceilings and 950 sq ft. I can get it to 80F in about 20 minutes.
The radiant tube heaters are way better, but cost more $$$. For me forced air was a better option.
Old Nov 24, 2011 | 01:07 AM
pankajs's Avatar
pankajs
Exactly what kind of things you want ?
Old Jan 15, 2021 | 08:05 AM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
2018 C1 of Year Finalist
My buddy has a 3 car - very high ceiling and very deep and he uses one of these
Heats up nicely - takes about an hour
https://www.tractorsupply.com/tsc/pr...heater-f299830
Old Jan 15, 2021 | 10:15 AM
djohn3853's Avatar
djohn3853
St. Jude Donor '21
Someone will jump all over you/us for resurrecting a 10 year old thread, but, since you mention the Mr Heater above, i'll give my take. I recently purchased this same heater. In a nutshell, so far disappointed. My garage is 24x26 and uninsulated and not sheet rocked. I guess i shouldn't have expected much, but still disappointed. the unit itself has no fan so the heat goes straight up. so i purchased the add-0n fan unit. it did little to help. It hasn't been particularly cold so far, and i've only owned the unit a couple weeks. I have 10 ft ceiling with storage trusses above. so the middle 12 feet of width has a plywood floor above. the outer 6 feet of each bay is open
Is your buddy's garage insulated?
Old Jan 15, 2021 | 02:58 PM
a1avette's Avatar
a1avette
I have a 24x28 garage and had a 45,000 BTU ceiling mounted propane Modine Hot Dawg installed a few years ago. I keep garage above freezing in winter and kick it up when I want to work on something. It has been trouble free and works great.
Old Jan 15, 2021 | 04:23 PM
RXTbone's Avatar
RXTbone
I have a 22 x 28 finished garage - 9 ft. ceiling and my little propane heater will heat it up to the point you have to turn it off...
Old Jan 15, 2021 | 06:18 PM
bc6152's Avatar
bc6152
HB4lthr probably bought his heater by now...
Old Jan 15, 2021 | 10:27 PM
59BlueSilver's Avatar
59BlueSilver
2023 Restomod of the Year Finalist
One reason I like the two burner that fits on a small propane bottle is because it’s portable. I use it mostly in my shop but occasionally I like to work in my garage so I carry it in there. Sometimes in the winter, our electricity goes out and may be out for a couple of days. I bring in the heater, crack a few windows, and be somewhat comfortable. I can also store it out of the way in the summer.
Old Jan 16, 2021 | 09:23 AM
eric22's Avatar
eric22
Exactly what I did, but mine was the 75k BTU model. Not big enough for my very large garage - should have gone bigger - but the larger models were significantly more expensive when I bought mine. It's a little noisy when running, but it does a good job. Just takes a little long to warm up the space since it's too small.
Old Jan 16, 2021 | 11:53 AM
  #33
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Thread from the dead yay.
I just open my family room door out to the garage. lol
I'm not baller so it's only 400 square foot.
Old Jan 16, 2021 | 12:06 PM
  #34
leadfoot4's Avatar
leadfoot4
Originally Posted by hb4lthr
Thanks. My ceiling is 9 ft. Where do you buy a Reznor gas heater from?
Try a local heating contractor.....
