valve spring compressor
Old Nov 26, 2011 | 07:11 PM
walleyejack's Avatar
walleyejack
Default valve spring compressor
I was trying to change my single springs for double springs,well the compressor I have will work for the singles, but it won't work on the double springs as the tangs are not long enough to grab both springs,it works for a bit,then you I really need to crank em down to get the locks on,the inner spring shoots out, any ideas on this would be helpful.
Thanks Al
Old Nov 26, 2011 | 07:25 PM
Qwik01's Avatar
Qwik01
What compressor do you have? The one I used had just enough room to allow the valve to go through it.
Old Nov 26, 2011 | 07:51 PM
walleyejack
I think it is KD, not sure, picked it up at NAPA.
Old Nov 27, 2011 | 09:40 AM
Qwik01's Avatar
Qwik01
Mine was just like this one.
Old Nov 27, 2011 | 09:47 AM
Qwik01's Avatar
Qwik01
I'm curious how the inner spring can even soot out? Since you are pressing both of them down with the retainer plate on top.
Old Nov 27, 2011 | 09:52 AM
walleyejack
when you grab the bottom of the spring, the tangs are not long enough to grab the inner spring, and of course the top is held in,when you start to tighten, the outer spring comresses past the inner spring, therefore it won't compress enough to the the locks on.
Old Nov 27, 2011 | 11:12 AM
bumble-z's Avatar
bumble-z
If your spring compressor is not like the one pictured in post #4, I would suggest getting one.
Good luck.
Old Nov 27, 2011 | 12:19 PM
walleyejack
Good luck.
what kind is that and where do you find it please
Old Nov 27, 2011 | 01:11 PM
bumble-z's Avatar
bumble-z
Crane Chevy Valve Spring Compressor
Summit Racing
Crane Cams #99472-1
You could check with other parts vendors here on the forum.
Thunder Racing?
With this unit you can do two springs at once.
Good luck
To valve spring compressor
