2001 C5 Coupe Brake Bleed Order
Nov 27, 2011 | 01:21 PM
Hi All,
Wondering what the correct bleed order is?
What does this depend on again distance from master cylinder?
Nov 27, 2011 | 02:04 PM
Correct me if wrong but I believe it's start with the one close to the master cylinder and work to the farthest.
Nov 27, 2011 | 02:21 PM
I didn't know it mattered?
Nov 27, 2011 | 02:36 PM
Nov 27, 2011 | 02:46 PM
Correct order is farthest first, so
A: Right (passenger) rear
B: Left (drivers) rear
C: Right (passenger) front
D: Left (drivers) front
Nov 27, 2011 | 02:50 PM
Quote:
Originally Posted by
wetelvis
Consider youeself corrected, It's just the opposite,
right rear
left rear
, right front
left front
Nov 27, 2011 | 02:56 PM
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I know you don't do the procedure like an older car because of the anti-loc brakes.
It is also different on the years because of location of the anti-loc unit.
Nov 27, 2011 | 10:18 PM
So is this correct for a 2001 based on the abs location?
When you say left that's the drivers side right?
Nov 27, 2011 | 10:55 PM
Bleed sequences. . . . .
97 - 00 RR LR RF LF
01 - 04 RR LF LR RF
And if I have to explain what's Left and Right you probably shouldn't be bleeding your own brakes anyway.
Nov 27, 2011 | 11:04 PM
Last C5
97 - 00 RR LR RF LF
01 - 04 RR LF LR RF
This is correct. Sequence changed in '01.
Nov 28, 2011 | 04:35 AM
Last C5 is correct. I just did my 04 in the order reccommended from the factory RR LF LR RF and no issues.
2001 ,
blead ,
bleed ,
bleeding ,
brake ,
brakes ,
c5 ,
corvette ,
order ,
procedure ,
sequence ,
z06
