[Z06] which Bilstein shock
Also, the ride is compromised unless the bumpstops are modified and/or the shock stroke is modified.
So, you can get away with lowering a C5Z and may not have ill effects. And yes the Bilsteins will control the car's motions better than OEM shocks. And no, not everyone here is trying to take their car racing or on the road course. But I just don't want to see misconceptions being the norm out there on the interwebs.
I find that hard to believe.
As far as ride heights are concerned, the lower you take the car on lowering bolts the more suspension travel you effectively lock out. Without moving to coilovers which have been designed specifically with aggressive lowering in mind, the lower you go the more likely you are to ride on the bumpstops. We recommend the users of our replacement shock options lower the car no more than the factory bolts allow, and suggest about a 1/2" drop for best handling and ride quality. Also keep in mind that every time you change your ride height you need to check your alignment as well, so when you're making adjustments to your lowering bolts make sure the car is the ride height you want it, THEN get an alignment. For good performance and tire wear on your mostly stock vehicles take a look at our Pfadt Racing Alignment Guide... a great alignment is absolutely worth the effort with these cars! Click the photo for access to a larger version, we don't want to post up a giant image that breaks forum tables.
Don't listen to this advice, it is absolutely the wrong thing to do. I hate to call MTPZ06 an idiot again, but he continues to spout this drivel that lowering the car all the way on stock bolts is fine. It isn't. If you lower it all the way on stock bolts the drop will be more than 3/4 of an inch. I don't know where MPTZ06 gets this information but it is absolutely false. We tested and measured and lowering the car all the way on stock bolts is a drop of an inch and a half. Maybe he was measuring from a car that was already lowered some, or maybe he didn't let it settle out, but if you drop the car all the way on stock bolts you will have about 4.5 inches of ground clearance in the front (as measured from the jacking points) and in the back you will have about an inch of travel on the rear shocks before you hit the bump stops. The stock ride heights (at the jacking points) are 6.02 and 6.22 inches (front/rear) respectively. This is from the workshop manual. It's a small but important point, but than additional 7/8 of an inch of suspension travel is really necessary to keep you from hitting the bump stops on a regular basis.
There's a litany of posts and experience and problems that people have experienced with excessive lowering, and it isn't any faster with the car lowered all the way on stock bolts (proven lots of times at the track).
There's a right way and wrong way to lower your car. Before you go out and start turning screws take a look at this post and do yourself a favor and do it right. Once you do it wrong you really should get the car corner weighted, or expect to take a good bit of time carefully measuring the ride height to straighten it out.
http://forums.corvetteforum.com/1576940245-post106.html
As I stated previously, you really need to work on your social skills...and stop being an idiot who calls everyone idiots who differ from your opinion. You really do appear to be a louzy human being.
