Replaced coolent overflow last week...
Old Nov 28, 2011 | 01:24 AM
Jesse Asis's Avatar
Jesse Asis
Default Replaced coolent overflow last week...
Well the coolent overflow tank nipple inlet cracked, leaking like a dam on the Hayward fault line (I hope it really isn't). Anyway I used the method from this forum on replacing it, can't seem to find it now but it helped, took only 30mins. and no issues what so ever. Leaving the cap on the tank prevented the coolent from pouring out when removing the hoses. Thanks Forum, you guys are life savers AGAIN.
Guys check your nipples, this apparently is a weak point. Looks like the weight of the hose bouncing around while driving puts strain on the plastic nipple (it does have a brass tube inside), cracking it at the joint to the tank. It started as a slow leak, then started heavy onto the exhaust..
Old Nov 28, 2011 | 08:03 AM
Glad you got it done. As these cars get older, more and more parts will face failure from stress on the components.
Old Nov 28, 2011 | 08:38 AM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Common area to leak for sure.
Old Nov 28, 2011 | 10:59 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Glad it was a simple fix
Old Nov 28, 2011 | 03:45 PM
PostShawn's Avatar
PostShawn
Mine was broke too and it was replaced a few months ago. Been holding coolant since but getting a low coolant message because I think the sensor is not properly seated or something and it's at the bottom of the tank from what I'm told. Probably have to just re-seat the tank.
Glad yours worked out.
Old Nov 28, 2011 | 04:36 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Excellent - just checked the nipples
Thanks,Matt
Old Nov 28, 2011 | 05:54 PM
Jim2003's Avatar
Jim2003
I am a professional Nipple checker!
Old Nov 28, 2011 | 06:28 PM
Big Duk's Avatar
Big Duk
I check nipples every chance I get!
Old Nov 28, 2011 | 08:16 PM
FYRARMS's Avatar
FYRARMS
Old Nov 29, 2011 | 02:59 AM
FourG63 97GST's Avatar
FourG63 97GST
Is this a coupe thing?, pretty sure mine didn't have a sensor
Old Nov 29, 2011 | 11:56 AM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Originally Posted by 8VETTE7
It's a 97 - 2000 thing. Sensor in the bottom of the surge tank. Different starting in 2001.
might want to double check that... I'm not sure on the Vette, but in the TransAm the level sensor was in the radiator and occasionally needed cleaning. Flushing the system didn't seem to help.
To Replaced coolent overflow last week...
