Lowered car
Old Nov 28, 2011 | 07:32 PM
onevettenut's Avatar
onevettenut
Default Lowered car
I lowered my 01 about 1.25". Of course the front air dam scrapes on everything, Has anyone cut the air dam the came amount as the car has been lowered. Will it affect the cooling
Thanks guys
Old Nov 28, 2011 | 07:38 PM
FourG63 97GST's Avatar
FourG63 97GST
cutting it does zero good, it's for aerodynamic and cooling. and it's designed to accept scraping. Remove it if you care of none of the above.
Old Nov 28, 2011 | 08:56 PM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
Cheap replacement if damaged
Old Nov 28, 2011 | 09:52 PM
4SFED Z's Avatar
4SFED Z
I trimmed mine 3/4 in. Perfect
Old Nov 28, 2011 | 10:30 PM
JETZ's Avatar
JETZ
A BIG 1.25 you say, and scrapes on EVERYTHING? That would really bother me!
Maybe you should raise it back up to 4X4 status if it bothers you so much. It's not hurting anything, and designed to flex.
Thanks guys
Old Nov 28, 2011 | 10:41 PM
onevettenut
Thanks for the input
Old Nov 28, 2011 | 10:58 PM
ZFLASH's Avatar
ZFLASH
St. Jude Donor '10-'11-'12-'13-'14, '16
Let it shave itself, then it would alright. Eventually it will be minor scraping, plus you get use to being more careful with dips. L8R ZFLASH
Old Nov 28, 2011 | 11:15 PM
onevettenut
that is a great idea, I will let it scrape until it quits
Old Nov 28, 2011 | 11:40 PM
jrose7004's Avatar
jrose7004
The air dam is self leveling if you drive it enough.
Old Nov 28, 2011 | 11:44 PM
striper's Avatar
striper
if it ain't scrapin', it ain't low enuff!
Old Nov 29, 2011 | 12:23 AM
SG Lou's Avatar
SG Lou
All Wise Words of Wisdom
Old Nov 29, 2011 | 09:37 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
I took mine off and have no cooling issues, the scraping was driving me nutz. But I do have screen in the front that help a lot
Old Nov 29, 2011 | 10:04 AM
Some owners have shaved the air dam off a bit to help with the scraping, but as mentioned, the parts are relatively cheap to replace and they are designed to flex when they come in contact with an object. Might just want to live with it for a while until you just replace the pieces.
Old Nov 29, 2011 | 08:59 PM
tsbbzm's Avatar
tsbbzm
No truer words have been spoken!!!
Old Nov 29, 2011 | 09:29 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
... LOL
Old Nov 29, 2011 | 10:40 PM
Xx_Black-out's Avatar
Xx_Black-out
St. Jude Donor '08-'11-'12
I love the scraping Hitting the switchbacks in the mountains and coming out of a low corner with the front scraping gives me a chubby!!!
Old Nov 29, 2011 | 10:49 PM
LMFD296's Avatar
LMFD296
To Lowered car
Old Nov 29, 2011 | 11:31 PM
vetfeva2's Avatar
vetfeva2
I measured the clearance that I had to the ground prior to lowering and then cut the air dam to give the same clearance. I figure it would give the same cooling affect. But like others said, it won't make a difference.
Old Nov 30, 2011 | 07:32 AM
Vato's Avatar
Vato
That actually looks pretty cool! Maybe I'll try it before ordering new ones.
Vato
Old Nov 30, 2011 | 12:53 PM
eldudereno's Avatar
eldudereno
After slamming my Z I trimmed 40mm off mine with no change at all in cooling performance.
