C5 Trivia
Old Nov 28, 2011 | 07:56 PM
philcon99's Avatar
philcon99
Default C5 Trivia
I found this recently and just wanted to share:
  • The 1997 Corvette features several first-time high tech innovations, such as black lights for the instrument panel and a "plastic" (composite) intake manifold.
  • The first 200 production C5 Corvettes were painted red, not the traditional white color for the first production run.
  • The 1997 Corvette is the first one designed from the ground up as a Corvette, with very little borrowing of parts from other cars. One of the few "Off the Shelf" parts are the exterior door handles which are the same ones used on the Oldsmobile Aurora.
  • The first use of a transaxle in a production Corvette occurred in the '97. However, the first plans for one were in the Q-Corvette in 1958, planned for the 1960 model. Transaxles showed up in Corvette prototypes in the mid '60s in running models.
  • The first 4 speed in a Corvette was built by Borg Warner in 1957. The first transaxle in a production Corvette was also built by Borg Warner, forty years later in 1997. Both were introduced late in the model year.
  • Borg Warner has produced a transmission for each generation of Corvette: C1 - 1957 to 1962, C2 - 1963, C3 - 1980 to 1981, C4 - 1984 to 1988, and C5 - 1997 to 1998.
  • The 1997 Corvette is the first Corvette to have windshield wipers that sweep in the same direction instead of opposing directions.
  • The 1998 Corvette convertible is the first to offer the same sport suspension package as the coupe. Since the C5 was designed from the start as a convertible model, the ragtop is nearly identical in structural rigidity to the coupe.
  • The first Corvette to sport a real trunk since 1962 again appeared with the 1998 Corvette convertible.
  • November 4, 1997 - The 9752nd 1998 Corvette rolled down the assembly matching the total 1997 Model production run.
  • The last "Fairway Green" C5 came down the assembly line as a '98 model on November 10, 1997. The color was discontinued due to poor sales.
  • It takes 55 hours to build the new C5 Corvette, down from 70 hours for the previous C4 model.
  • For the first time in history, the 1999 Corvette is available in three disctinct body styles... Coupe, Convertible, and Hardtop (aka, "Fixed Roof Coupe").
  • The performance axle ratio for C5 Corvettes with automatic transmission is 3.15:1 (the standard ratio is 2.73:1).
  • The 2000 Corvette featured new color choices to celebrate Y2K... Millenium Yellow and Dark Bowling Green Metallic... plus a new Torch Red interior option.
  • 2001 will forever be remembered as the year the Z06 performance hardtop was introduced with its 385HP LS6 engine and 6 speed manual transmission.
  • Corvette's use of a titanium exhaust for the Z06 was the first ever for a mass production automobile.
  • Active Handling became standard equipment in 2001.
  • The 2002 Corvette featured a new color, Electron Blue Metallic, and an upgraded 405HP LS6 engine for the Z06.
  • The 2002 Z06 windshield was thinner than that used in the coupe models, shaving 2.65 pounds per car. The lighter windshield was shared with convertibles equipped with the Heads Up Display (HUD) option, which was standard on 2002 Z06 models.
  • The 2003 Corvette heralds the 50th anniversary with a special edition in Anniversary Red with Shale interior and a new, high-tech magnetic suspension option for all models but the Z06, which continues essentially unchanged from the 2002 model year.
  • In addition to Anniversary Red, Medium Spiral Gray Metallic was a new color in 2003.
  • The Magnetic Ride Option offered in 2003 uses a magnetic fluid which adjusts shock damping 1,000 times per second, roughly equivalent to reacting to each inch of road surface at 60 mph.
  • 2004 marks the last of the extremely successful fifth generation Corvette and was celebrated with the special Commemorative Edition Corvettes in Lemans Blue with special badging, graphics and interior appointments.
My apologies if this was posted before.
Old Nov 28, 2011 | 08:48 PM
Cosmic Charlie's Avatar
Cosmic Charlie
A stroll down memory lane ...
Old Nov 28, 2011 | 09:00 PM
VETJAZZ's Avatar
VETJAZZ
Old Nov 28, 2011 | 09:01 PM
papafrancisco's Avatar
papafrancisco
Good stuff. Now I'm a wee bit more knowledgable.
Old Nov 28, 2011 | 09:17 PM
HERK's Avatar
HERK
Old Nov 28, 2011 | 09:25 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
b.lee's Avatar
b.lee
Thanks for posting
Some interesting info in there.
Old Nov 28, 2011 | 10:02 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
thanks
Old Nov 28, 2011 | 10:08 PM
JETZ's Avatar
JETZ
Old Nov 28, 2011 | 10:38 PM
LS2NSUV's Avatar
LS2NSUV
C5 is the first corvette with windshield wipers sweeping in the same direction? I had no idea. Gonna pay closer attention to this.
BTW. Cool info.
Old Nov 29, 2011 | 10:21 AM
Have seen that list before, but still an interesting read to see how the C5 broke new ground.
Old Nov 29, 2011 | 10:41 AM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
BTW. Cool info.
That one was new to me
Old Nov 29, 2011 | 11:49 AM
Cirrus8's Avatar
Cirrus8
Great information. It was a fun read.
Old Nov 29, 2011 | 01:08 PM
buddyroth's Avatar
buddyroth
Thanks. Interesting.
But I question the use of the term transaxle. If I understand correctly, a transaxle contains the transmission and differential in one unit. I think our C5's have separate units even though they are closely coupled. If I'm wrong, someone please correct me.
Old Dec 7, 2011 | 05:56 AM
OMGDUDEWTF's Avatar
OMGDUDEWTF
good info
Old Dec 7, 2011 | 06:34 AM
Cybermind's Avatar
Cybermind
Yes and no. Yes, they are two separate closely coupled units. But this creates one single drive assembly in the rear of the car and thus the term "transaxle". Most sports cars that have this "rear transaxle, front engine" setup contain separate, closely-coupled transmission and differentials, similar to the C5. Normally, rear-engined sports cars with transversely mounted engines will have the transmission and differential housed in a single unit. This is similar to a typical front wheel drive car except the engine and transmission would be mounted in the back.
Old Dec 7, 2011 | 08:02 AM
buddyroth's Avatar
buddyroth
Thanks for the comment. I continue to be amazed at the amount of engineering crammed into such a small package as our C5's.
To C5 Trivia
Old Dec 7, 2011 | 02:49 PM
WetteVette's Avatar
WetteVette
Default Info
Great info! I've also heard that the C5 has approximately 1,400 less parts than the C4.
I know it's been mentioned many times before, but if you want to know just about anything about the C5, read All Corvettes Are Red.
Old Dec 7, 2011 | 06:40 PM
Pfadt Racing's Avatar
Pfadt Racing
That looks awfully familiar... that's definitely a billboard in Salt Lake City!
For a fantastic little track car at a great price point, the C5 is a screaming deal in today's market. We sure do love making them faster!
Old Dec 9, 2011 | 07:17 AM
WvCorvette's Avatar
WvCorvette
