Nitrous fitting question
Old Dec 2, 2011 | 12:19 PM
liveaboard74's Avatar
liveaboard74
Default Nitrous fitting question
What I'm wanting is a through the body Purge fitting. Not the long tubs that most of us have on the cars but one that you can drill a hole mount in the body and tighten it up with a nut on the underside then connect it to the lines that run from the purge unit.
I seen one some where and can not find it now. Doing a custom back end and changed everything around in the car and running the lines different. Contacted Zex and they don't make one and it should not be that hard to make but wanted to see if anyone knew of a dealer that sold one or knows of anyone that does.
Seen it on e bay a while back and thought it was nice but went to buy it and now I can't find one.
Any help would be nice.
Thanks......
Old Dec 2, 2011 | 02:10 PM
igtabg1's Avatar
igtabg1
Default like this...
Like this?
http://www.dynotunenitrous.com/store...p?idproduct=34
Old Dec 2, 2011 | 02:23 PM
liveaboard74
No but thanks. Almost looks like ONE of these jets but with threads on the bottom. Drill a hole where the T part of the jet will stop on the body pannel and then you could connect a locking nut or secure it on the bottom then the nitrous line. Makes it a flush mount Nitrous purge nozel.
To Nitrous fitting question
