Rear Leaf spring adjustment bolt issue???
Old Dec 6, 2011 | 07:46 PM
XXXcorvette's Avatar
XXXcorvette
Default Rear Leaf spring adjustment bolt issue???
Hey all, Just recently replaced the OEM rear leaf Bushings with the Energy kit and had a concern. Before I loosened the bolts however I measured the bolts and the nuts were tightened to 2 different heights. The drivers side nut was on about 13mm and the passengers side about 25mm. I measured these from the springclip retainer. Is that normal? With the new rear bushing kit installed in A-Arms now and the shorter leaf spring bushing should I re-tighen, maxtighten, close gap or what???
