C5 clutch upgrade
Old Dec 7, 2011 | 03:25 PM
Frozenfire's Avatar
Frozenfire
Default C5 clutch upgrade
It looks like it's time for a new clutch on the vert. Someone suggested purchasing a Z06 clutch upgrade kit rather than replacing with stock. Has anyone on the C5G done this? A good idea?
Old Dec 7, 2011 | 04:32 PM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
There are lots of aftermarket clutches out there, but I did just what you're suggesting. The Z06 clutch was something like $20 more than the stock clutch and the install was exactly the same as stock. However, there may be some better aftermarket options for the same price or less. I'm sure others will chime in. Zuti
Old Dec 7, 2011 | 06:04 PM
Qwik01's Avatar
Qwik01
LS7 clutch here. Love it.
Old Dec 7, 2011 | 08:29 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
LS7 clutch is the way to go....good for well over 400rwhp.
Old Dec 7, 2011 | 08:38 PM
Edmond's Avatar
Edmond
Unless you're going with big power, the LS7 clutch is the way to go. Just be sure to replace the hydraulics, throwout bearing, install a speed bleeder and use new bolts on the pressure plate and flywheel. Make sure you get the torque specs and pattern correct for those bolts as well. A factory shop manual will pay for itself after this job.
barrynk's Avatar
barrynk
I had the LS7 installed a month ago when my 480rwhp became too much for the stock clutch. So far so good, close to stock feel.
Old Dec 7, 2011 | 10:54 PM
Frozenfire's Avatar
Frozenfire
Thanks everyone! The grinding noises suggest it needs a new throwout bearing, so I'll replace the clutch as well while it's ripped apart.
Old Dec 7, 2011 | 11:27 PM
Not that I need it since I have an A4, but good to know that the LS7 clutch will work on the C5.
To C5 clutch upgrade
