LED DRLs
Old Dec 9, 2011 | 04:58 AM
Kamauxx's Avatar
Kamauxx
Default LED DRLs
The type you see on Audis. Anyone here make em for the C5?
Old Dec 9, 2011 | 06:29 AM
jdmvette's Avatar
jdmvette
Night Owl for life
yes.
Old Dec 9, 2011 | 08:16 AM
Kamauxx's Avatar
Kamauxx
Who?
Old Dec 9, 2011 | 08:57 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Remember too that the DRL's are your front blinkers too.
Old Dec 9, 2011 | 09:02 AM
k0ts's Avatar
k0ts
They are just a standard 3157 bulbs.. You can find LED replacements at about any auto supply.. (or on the web) You will, however, have what's called "hyperflash"..
The LEDs draw far less current and the turn signal flasher unit will think the bulb is burned out and will flash faster than normal. You should be able to find a fix for that by googling "hyperflash"..
LEDs do not product the heat that the incandescent bulbs do so DRL housings will survive longer. It's not a big problem but sometimes the bulb heat causes a hole to form over the bulbs allowing water in which destroyers the bulbs. I fixed mine but putting silicon sealant over the holes..
Old Dec 9, 2011 | 09:17 AM
Check with forum member TheRadioFlyer (forum vendor) or JW Motoring.
Old Dec 9, 2011 | 10:07 AM
cal45's Avatar
cal45
Not the dot style of the Audi's but I replaced my factory amber DRL bulbs with white LED bulbs.
Old Dec 9, 2011 | 01:45 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
i just ordered clear corners with the LED strip option from JW. jhonathan is great to deal with.
Old Dec 9, 2011 | 02:35 PM
wally2004's Avatar
wally2004
St. Jude Donor '11
I put on clear corners with LED DRL's and LED strip from JW Motoring. Had a headlight go out and didn't even notice because corners are so bright now! Check with Jhonathan.
Old Dec 9, 2011 | 03:26 PM
bucwheat's Avatar
bucwheat
I know JW has them for sure,radio can make them
Old Dec 9, 2011 | 04:08 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Thanks for those that suggested us.
George you can have this one
Old Dec 10, 2011 | 03:36 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by Kamauxx
Who?
these are audi style.
http://forums.corvetteforum.com/c5-g...er-lights.html
Old Dec 11, 2011 | 12:59 PM
algoma's Avatar
algoma
Clear Corners w/ LED stripes from JW Motoring!!!
Just looks great IMO
Allan
Denmark
To LED DRLs
