[Z06] fluid swap ????
Old Dec 11, 2011 | 08:33 PM
nosgsxr's Avatar
nosgsxr
Default fluid swap ????
ok i just got a 03 zo6..it has 75000 on it and want to do a full fluid swap...my question is what kind and how much of each do i need
i read alot of threads but the all seem to get into a fight about who makes the best and who dont ..so please help me out...
oil
tran
rear diff
i sure im gonna run moble 1 for the oil but not sure on how much i need to buy i would like to do the full synthetic swap thanks
Old Dec 11, 2011 | 09:32 PM
JeremyGSU's Avatar
JeremyGSU
No idea about tranny/diff but manual says 6.5 quarts for oil. I've read numerous threads where guys run 7.0. Manual says add one quart over for track days so that's 7.5 quarts.
I'm currently running around 7 all the time.
Old Dec 11, 2011 | 09:48 PM
nosgsxr's Avatar
nosgsxr
wow 7 quarts...i guess thats what i will do ...not much racing here but i do get on it some
Old Dec 11, 2011 | 11:36 PM
MTPZ06's Avatar
MTPZ06
4 quarts (1 gal) Trans and 2 quarts diff. My recommendation is Amsoil for these. Just picked some up from forum member "Subdriver"...shipped right to my door and paid less than I did for royal purple off the shelf a couple years ago.
Old Dec 12, 2011 | 01:48 AM
LT1driver's Avatar
LT1driver
Pine Bluff, AR..been there done that many moons ago
Old Dec 12, 2011 | 10:34 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I wrote a procedure to swap the Diff, and Tranny fluids on my web site.
I plan to do an oil change procedure next time I do mine in the spring. There are a few procedures out there for it though. You will need 6.5 qts to fill it. So buy 7 qts.
Its on my web site..... www.ToqueZ06.com
Scroll to the bottom and click on:
--> C5 6 Speed Manual Fluid change:
--> C5 Rear Differential Fluid change:
Hope this helps.
Toque
Old Dec 12, 2011 | 06:05 PM
MY03C5Z's Avatar
MY03C5Z
I just picked up my 03z last month with 36k on it and changed all 3 fluids. Used Mobil 1 for each. 6.5qts 5w30 for engine, 4 qts ATF for trans, 2 qts of 75w90 plus small bottle of GM LSD additive for rear. All 3 were very easy jobs, I was surprised at how easy the trans and rear were to change, not a hard job at all imo.
I've also done the clutch master cylinder flush/change and the coolant flush. The clutch master cylinder fluid didnt look like it had ever been changed but the coolant looked like it just came out of the bottle. Previous owner must have done it really recently.
Old Dec 13, 2011 | 09:30 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
The fluids AMSOIL recommends for your engine oil, tranny and diff:
AMSOIL Signature Series 100% Synthetic 5w30 (Product Code ASLQT) (takes ~ 7 qts)
AMSOIL Torque-Drive Synthetic Transmission Fluid (Product Code ATD1G) (takes ~ 3.5 qts - this is 1 gal size)
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT) (takes ~ 1.7 qts)
Note that the Severe Gear comes with friction modifier already in it and adding extra modifier is not normally needed for the C5. I personally have been using the tranny and diff fluid in my 02 Z06 at the track for years without failure, but I use AMSOIL's racing engine oil. That said, I did use AMSOIL's top tier Sig Series 0w30 in my CTS-V (LS-2 engine) while it was my daily driver from 06-09 and I get very low wear metal results with the AMSOIL (Jun 07 sample was M1 5w30, the rest AMSOIL):
Cadillac CTS-V Used Oil Analysis - AMSOIL 0w30
If you do opt for the AMSOIL fluids, more than happy to get them for you at wholesale, about 25% off, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
MTPZ06 - thanks for the mention!
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Dec 13, 2011 | 10:23 PM
nosgsxr's Avatar
nosgsxr
thanks yall for all the input...i went with amsoil an got it from "subdriver" he is a great person to talk to and very helpful... he know his oils...lol thanks again for the help yall are GREAT
Old Dec 14, 2011 | 09:38 PM
C66 Racing's Avatar
C66 Racing
I appreciate the order. Your fluids should arrive tomorrow - enjoy your new Z06 and have fun with the fluid swap this weekend.
To fluid swap ????
