Man day
Old Dec 12, 2011 | 04:36 PM
johnson-rod's Avatar
johnson-rod
Default Man day
Did you ever get caught up in a vortex of car repairs? Sure you have.
Mine started innocently enough with the semi-annual front tire swap. I got up early on Saturday (the wife is away) and pulled the front wheels off and took them to the local tire shop. They did them immediately which is way faster than I had planned. Since I had the front end up and I had the extra time I took a look at my front brakes. They are original with 102K miles and that's pushing it even for me. So I picked up some ceramics for the front and rears. I'll do the rears some other time.
The driver's side went very easy and so did the passenger side. Now the bottom of the passenger side front fender has never lined up well so I decided to pull the inner fender well to check out why. Also there is a rattle in that fender that is really annoying. After pulling off the access panel I could see that a bolt was missing that holds the middle of the fender to the cowling. After checking every possible location in the house for a similar bolt I finally went with a little screw and nut. Then I had to re-do the connection on the bottom of the fender because it was based upon the bulging fender profile. I also was able to cleanout the elusive and shy passenger side udder.
Fender looks good now but the rattle is still there. I find the cove inner backing is only attached at the front and rattles against the fender at the back. So I use an unused EZ Pass velcro to attach the back of the cove backing. Success! Front wheels back on. I don't really want to drag the floor jack back out again so I pickup the back of the car and start on the rear brakes.
Like every sports car I've ever owned this parking brake has sucked since day one. So while I've got the calipers off, I pull the caliper brackets off then the rotors. I adjust up the parking brake shoes and remount the rotors, brackets, calipers and new pads. Seems like a shame to do all this without flushing the old brake fluid so I pull out the vacuum pump and suck out the brake fluid and refill with new. As I wipe off the master cylinder I see right next to it is the clutch master cylinder so what the heck I do that too.
On the test drive I hear that blower motor squeal that my wife mentioned so I pull the passenger footwell apart and lube the blower motor bearing. Also the clear targa top has been rattling so I adjusted that too. By now it's pitch black and I'll have to put off that HID kit install til the next day my wife's away.
Old Dec 12, 2011 | 05:07 PM
Paul Wood's Avatar
Paul Wood
I wish I had as much ability and resolve as you do! I am proud of you and only wish you lived closer to me so that some of that could rub off on me! Nice job and congrats!
Good Luck.
Old Dec 12, 2011 | 05:16 PM
You did have a busy, but very productive day.
Old Dec 12, 2011 | 05:36 PM
coia96vette's Avatar
coia96vette
Nice job! Nothing like some quality time with your vette. Looking forward to getting some with mine. We will see what the weather here in northern IL has in store for this weekend.
Old Dec 12, 2011 | 05:38 PM
Dope's Avatar
Dope
Resident moron
Yes, but it usually escalates even worse. Next thing I know I have the drivetrain laying in the driveway when I started by replacing the wiper blades.
Dope
Old Dec 12, 2011 | 05:54 PM
chasboy's Avatar
chasboy
Oldtimer
that area of NJ is well known for hard workers!!!
"Trenton Makes, and the World Takes"
Old Dec 12, 2011 | 06:18 PM
jrose7004's Avatar
jrose7004
You spent some really quailty time with your car! Congrats.
Old Dec 12, 2011 | 06:31 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
This is what's called "Preventative Maintenance" and I applaud you for making the effort and doing it right. So many people don't do the simple things you did, then they start complaining about how this is broke or that doesn't work and so on....
Old Dec 12, 2011 | 06:54 PM
Kmcoldcars's Avatar
Kmcoldcars
I am really envious. You did all of that work and did not mention bleeding even once. How did you do it????
Old Dec 12, 2011 | 07:03 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Only a few short years ago my eyes would have glassed over reading this and most threads such as yours. I knew very little about my Vette. Thanks to many here on this forum I have gained enough knowledge so that I needed and purchased a WAY bigger toolbox and tools! I can't believe how much I have learned.
Great Man Day!
Old Dec 12, 2011 | 07:34 PM
68ragtop69's Avatar
68ragtop69
MD Events Coordinator
2015 C3 of Year Finalist
Cruise-In X Veteran
CI-X Car Show Winner
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
I wish I had that much time to spend with my mistresses!!!
Old Dec 12, 2011 | 10:41 PM
johnson-rod
Thanks guys. I can almost stand up straight now.
Old Dec 12, 2011 | 10:52 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Old Dec 12, 2011 | 10:56 PM
C5FORFUN2's Avatar
C5FORFUN2
Sounds like a GREAT time!!
Old Dec 12, 2011 | 11:02 PM
jcsperson's Avatar
jcsperson
NC Events Coordinator
My wife rates my jobs on a cursing scale. A "one sonuvabitch" job went pretty smoothly. A "two sonuvabitch" not so much. A "three sonuvabitch" job is a PITA and a "four sonuvabitch" means it's time for professional help.
Chasing down rattles, squeaks and vibrations is often a "three sonuvabitch" job. Sometimes it gets raised a degree of difficulty with an f-bomb between the "threesonuva" and "bitch." You are to be commended for your patience, especially if it didn't involve cursing.
Old Dec 13, 2011 | 12:55 AM
itzza427's Avatar
itzza427
Sounds like you had a serious case of "Might as Wells"!!I know you were tired,,aching but well satisfied. Major congrats to ya!!!
Old Dec 13, 2011 | 01:08 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Aint it great when it all works out
To Man day
Old Dec 13, 2011 | 04:24 AM
airbrush1's Avatar
airbrush1
Dope
Sounds like me once I'm in the mood, I can't leave well enough alone!
Old Dec 13, 2011 | 06:31 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
I love spending time in my garage, it might be with my car, my wife’s car, the Suburban or a friend’s car but its always enjoyable. Sometimes I like to go at it alone, other times it s nice to have a friend or two over. I am off next week so I am hoping to have some car time, I do have some woodworking to do so I know I have garage time!
Old Dec 13, 2011 | 10:08 AM
roscoe118's Avatar
roscoe118
...I took a look at my front brakes. They are original with 102K miles and that's pushing it even for me...
Nice work!!!
