If you want to stick with the gm fluid, just go to the dealer and request the correct fluid for your vette. Personally I like the amsoil but to each his own.
I want to stick with the GM stuff.
Which is the correct fluid...
75W90 or 75W90LS?
I think the LS is for C6's but I'm not sure.
Probably a good time to change the trans fluid too if you haven't done that in a while. I typically do the diff and trans at the same time...makes service intervals easy to remember.
Just hope it doesn't turn out to be "backwards compatible" like the Dexron VI to Dexron III ....then 2 yrs later the addendum...."EXCEPT in manual transmissions"!http://images.ibsrv.net/ibsrv/res/sr...ilies/ack2.gif
Good question, but no. The Dexron LS has been out for years now - you should be fine with this fluid. It has the same viscosity but different friction properties than the older version (both are 75w90s). In the case of Dexron III and VI, GM dropped the viscosity of the VI by about 40% - totally different behavior of the fluids. They almost immediately backed off on their recommendation that the VI was backwards compatible for manual trannies.
Interesting!
So what exactly happens (happened) to the C5 guys who put Dex VI in their M6's?!!
