C5 design flaw??
Old Dec 21, 2011 | 09:42 AM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
Default C5 design flaw??
I have experienced something that I'm sure others have. Whenever I open my hatch (coupe car) after it has rained or the car has been washed, the standing water on the surface runs down the hatch, and follows the rubber weather stripping where it falls off into the car and into the hole behind the rear speaker where the shock towers go.
While this may not hurt anything, it makes me nervous that it goes in the little hole where the speaker is so close.
If anybody has a fix for this, I'd like to hear it.
Old Dec 21, 2011 | 10:26 AM
Bluefire's Avatar
Bluefire
My "fix" is when I open it I only lift it 1/2 way. This lets the majority of the water run off into the proper channel. Then I lift it all of the way up.
It works for me.
Old Dec 21, 2011 | 10:41 AM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
I had a C-4 that I noticed did the same (now have a FRC). I believe I read a magazine piece about dealing with the issue on C-4's & it involved drilling a couple of holes & installing a short piece of tubing for draining. I didn't pay too much attention after I read about "drilling holes" in my vette, ha, ha...I kept a rag handy when I owned the C-4...
Old Dec 21, 2011 | 10:51 AM
m6 c5's Avatar
m6 c5
It was a flaw in the first couple of years and was fixed by adding an extra piece of rubber to the weather stripping which kicks most of it out.
Old Dec 21, 2011 | 11:00 AM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
Is that what the "tail" piece is for at the end of the rubber strip.
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
. My 02 does not do that.
Old Dec 21, 2011 | 11:30 AM
m6 c5's Avatar
m6 c5
Yep, Im not sure when they changed it but I think it was in 99 I can say for sure that it was changed by 2000 though.
Old Dec 21, 2011 | 11:33 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I really don't think that is going to drain near the speaker, it runs back about 6-8 inches and there is a hole that would be close to the gas filler. I am almost sure those are drain holes that channel the water outside the interior. If you look at the rear area where the hatch closes there are two more area in the left and right rear corner that will do the same thing.
Old Dec 21, 2011 | 11:37 AM
m6 c5's Avatar
m6 c5
Its the water that is actually on the rear hatch that rolls down where the glass meets the hatch and then off the front facing section. If you have an early model C5 then the water will pour into the cargo area where as if you have a post 99 or 2000 then you will have a little extra tail on the weather stripping which will kick most of the water out and into the channels you are talking about.
Old Dec 21, 2011 | 11:47 AM
Jewjenk's Avatar
Jewjenk
Kinda late to worry about a design flaw or perceived one..
Old Dec 21, 2011 | 11:55 AM
damilleniumboy's Avatar
damilleniumboy
I have never washed mine, so I don't have that problem.
Old Dec 21, 2011 | 11:59 AM
BigTattooMan
St. Jude Donor '10
Mine is a 99
Old Dec 21, 2011 | 12:14 PM
J S Machine
I do recall a little tail thing on mine, although I don't know if it is what yall are talking about.
As the other poster said, the only way to avoid it is to open it half way.
Old Dec 21, 2011 | 12:51 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
nope..my 99 does it...
it was absolutely fixed on my 07 though
FWIW her 02 is not much better..that tail doesn't do jack
Old Dec 21, 2011 | 04:02 PM
Bluefire's Avatar
Bluefire
My '03 tail is useless too.
Old Dec 21, 2011 | 04:16 PM
jrose7004's Avatar
jrose7004
That hasn't really caused me any problem.
Old Dec 21, 2011 | 04:20 PM
m6 c5's Avatar
m6 c5
It works really well on my passenger side and the one on the drivers side is bent but compared to my dads 97 its night and day difference.
To C5 design flaw??
Old Dec 21, 2011 | 04:27 PM
Oldvetter's Avatar
Oldvetter
Default No design flaw !
I agree that they "fixed" this on later C5s, but I remember reading in "All Corvettes are Red" book that the early C5s had waterproof rear speakers, so NO DESIGN FLAW.
Old Dec 21, 2011 | 04:39 PM
J S Machine
ok well that settles it
waterproof speakers for the win
Old Dec 21, 2011 | 04:56 PM
Big Duk's Avatar
Big Duk
Ask Evil Twin
