steering question
Old Dec 21, 2011 | 11:20 PM
Pinski 1's Avatar
Pinski 1
Default steering question
I have a 97 auto w/ 75k miles. When I am going into a corner hard it feels like my steering wheel catches and I really have to turn it hard into the corner to release it. It is hard to explain but it is not smooth at all. At low speeds there is no problem at all. I took my friends 04 out and it is much, much smoother turning at all speeds than mine. his even seems like it has a quicker steering ratio than mine. We have the same tires so it cant be that. Everything looks good under the hood, fluids are fine.Any input would be great. Thanks !
Old Dec 21, 2011 | 11:37 PM
jrose7004's Avatar
jrose7004
I can certainly tel youl that my 04 coupe doesn't feel that way.
Old Dec 22, 2011 | 12:28 AM
m6 c5's Avatar
m6 c5
Kinda sounds like you are losing pressure to the rack somehow.
Old Dec 22, 2011 | 01:56 AM
Dixiecrat's Avatar
Dixiecrat
Think his steering column might be trying to lock up ? !
Old Dec 22, 2011 | 08:16 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Well, whatever the cause, its not normal and it sounds a bit dangerous. Pull your codes. Check the magnasteer connector and insure its plugged in from the rack to the harnesss
Old Dec 22, 2011 | 10:11 AM
mcm95403's Avatar
mcm95403
Check the condition of the fluid. If it's dark or smells bad it's time to replace it. Problem there is that the pump and/or rack may have been damaged by broken down fluid not lubricating correctly. Obviously that could be costly.
It could also be belt slippage casuing the pump to lose pressure. Check to see that your belt is still in spec and not polished looking, which could let it slip.
Marc at vettenutz.net would be a great source for used replacement parts.
Old Dec 22, 2011 | 05:28 PM
Pinski 1's Avatar
Pinski 1
There are no codes showing up at all.I checked the fluid and it seems fine. However, I purchased the car used and I have never changed the fluid. There is a good chance that it is original but with only 75k on it I didnt think it was a big deal. I changed the belt when purchased so that is in good shape. Just seeing if anyone has had a problem with the rack before.
Old Dec 22, 2011 | 08:22 PM
m6 c5's Avatar
m6 c5
Try changing the fluid out and bleeding the system, if there is air in the line I would think it would cause what you are feeling.
To steering question
