ground
Old Dec 22, 2011 | 09:29 AM
black match box's Avatar
black match box
Default ground
This winter I thought I would clean all the ground wires on the vette, question is do I need to remove the neg. term. on the battery or can it be done with out removing it? should I put dielectric grease on them when cleaned? I have all the grd. point locations, any thought would be appreciated. (GINO) HAPPY HOLIDAYS TO ALL AND TO ALL A HAPPY NEW YEAR. MAY THE FLEAS OF THOUSEND CAMELS STAY AWAY FROM OUR CARS.
Old Dec 22, 2011 | 10:47 AM
roscoe118's Avatar
roscoe118
^^^What he said...
Old Dec 22, 2011 | 12:04 PM
Jistari's Avatar
Jistari
Originally Posted by 8VETTE7
When your playing with the electrics on these cars it is ALWAYS a good idea to disconnect the battery Neg. cable......
I would NOT use "dielectric grease" on the cleaned connections.
Why is that 87? I did mine a long time ago and I think I did use the di-electric. Just wondering why that wouldn't be a good idea?
Old Dec 22, 2011 | 01:27 PM
robert miller's Avatar
robert miller
100%
Old Dec 22, 2011 | 02:23 PM
guido7834's Avatar
guido7834
Any diagrams on the ground point locations? Something I may want to tackle.
Old Dec 22, 2011 | 02:52 PM
Alex1's Avatar
Alex1
8VETTE7 and Bill Curlee really know this cars electrical system!
I was cleaning the one on top of the passenger side wheel well and when reconnecting some relays started clicking.
you will find the locations in here. Here is Bill Curlee's sticky. very good read:
http://forums.corvetteforum.com/c5-t...tion-long.html
I used De-ox on my connectors after sanding them with a scotchbrite pad. The green hue on the pins also will give it away.
Old Dec 22, 2011 | 10:41 PM
raydawg357's Avatar
raydawg357
Old Dec 26, 2011 | 08:00 AM
Gadget01's Avatar
Gadget01
Sorry, but this post contains some bad information. Your quote about dielectic grease is correct but your understanding is apparently incomplete or I read it wrong or your wrote it wrong... or any combo of any of that.
Dielectric grease is a silicone-based lubricant that does not conduct electricity. This is a very useful property to both waterproof and prevent corrosion on electrical connections. Because the grease does not conduct electricity, it will not interfere or scavenge power from the electrical current going through the connection.
Covering a ground connection (after it is made) with this stuff may help precent corrosion but if you get the grease warm enough (ie engine compartment) it is going to flow and may get between the metal contacting surfaces, especially the stranded wire connections that are crimped on. That may serve to reduce the metal to metal contact needed for a solid ground point. If you look carefully the C5 has crimped connections while on the C6 GM went to soldered connections. So I would NOT use it for those reasons.
As always YMMV.
Mostly disagreed.
Any electrical connection in an outdoor environment would be best insulated from any contact with the air since it always carries moisture. The green funk you see on wire or connectors is electrolysis, which in this case is a result of a poor connection exposed to moisture and/or oxygen.
Using a small amount (just enough for a light coat) on the multi-pin ground distribution connector pins/pin sockets will insulate them from air and thus prevent corrosion and drastically slow down electrolysis. Dielectric grease is not thick enough to prevent a connection between the pin and its socket. The grease gets pushed out of the way and fills the voids normally occupied by air. If you use it liberally enough, the grease will ooze all over once the air pockets are filled and then you have a little mess to clean up, but no big deal. It will not, as you suggested, prevent the connection from being made. Even if it were to get warm enough for gravity and engine vibrations to make it ooze out and get lucky enough to fall on another ground connection (highly unlikely anyways) it would do more help than harm anyways.
Speaking of crimped-on connectors for stranded wire- no treatment could be better than dielectric grease packed into the exposed wire strands and into the connector prior to it being crimped. To really "seal" the deal, insulate the bare end with shrink-tube while some excess grease is still there. The grease WILL NOT interfere with the electrical connection despite the fact of it being non-conductive... it is not intuitive, I know.
Here's another thread, same-ish subject:
http://forums.corvetteforum.com/audi...-location.html
and a video: http://www.youtube.com/watch?v=8W7o-CRRmGo
Nevermind the product endorsement, which is not implied or intended.
Experiment with it... clean the pins from two of your ground distribution connectors and for one of them, coat the pins with a light application of dielectric grease. Check them both in 6 months. The difference will be more pronounced with greater exposure to moist air... driving in the rain or in the southeast... outdoor storage, etc.
Next time you change light bulbs... use a little dielectric grease on the threads/connector pins. There are dozens of practical applications where it really helps. Google is your friend.
Old Dec 26, 2011 | 06:46 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by raydawg357
Is #4 on the inside of the car?
Old Dec 26, 2011 | 07:51 PM
AngryTurtle's Avatar
AngryTurtle
Playing with every ground wire on the car seems like it would be begging for something to go wrong.
To ground
