Front tire size?
Old Dec 22, 2011 | 10:39 AM
OHIO-C5's Avatar
OHIO-C5
Default Front tire size?
Trying to decide on which front tire size to use. rear wheels are 19x10 with 305-30-19's, front wheels are 18x9.5. thinking 265 or 275-35-18. thanks
Old Dec 22, 2011 | 10:49 AM
runner140*'s Avatar
runner140*
Spend a few minutes in the Tire Rack web site. That should answer some of your questions. (ie size and brand etc.).
Old Dec 22, 2011 | 10:50 AM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
You could get by with the 275s, but in this case, the 265s are a better choice.
Old Dec 22, 2011 | 10:44 PM
Mickeyrx70's Avatar
Mickeyrx70
Default tire size
I have same wheel setup as you with 275/35/18 Goodyear Eagle F1 EMT supercars up front;305/30/19 Michelin Pilot Sports in back -- works fine.
Old Dec 23, 2011 | 10:16 AM
Russ K's Avatar
Russ K
265/35/18 as the sidewall on a 275/35/18 is noticeably taller than the 305/30/19. Or you could use a 285/35/19 on the rear which is closer to the stock C5 dia.
Russ Kemp
Old Dec 23, 2011 | 01:58 PM
99 vett babycar's Avatar
99 vett babycar
I've had both 275 and 265 with 295 rears - the 265 felt a lot better.
To Front tire size?
