[Z06] Eneven exhaust tip issue
Old Dec 22, 2011 | 12:09 PM
Evil Oil Apologist's Avatar
Evil Oil Apologist
Default Eneven exhaust tip issue/ UPDATE
'03 Z06, stock TI exhaust, LG Pro headers, and lowered.
I'll get the car in the air on Friday to inspect. Other than a bent hanger or tired strap..........anything else that might be the culprit?
There has been some scrapping encounters with driveway high points and speed bumps, but nothing serious at speed.
Old Dec 22, 2011 | 12:53 PM
1FUNC5's Avatar
1FUNC5
one side of the pipe between headers and muffler flange probably needs to be twisted
Old Dec 22, 2011 | 01:24 PM
Dennis Wilson's Avatar
Dennis Wilson
I had the same prob. one side sagging a bit. I loosened the strap around the TI muffler on the lower one, pushed up on tips and retightened strap and solved problem . Good luck!
Old Dec 22, 2011 | 05:09 PM
Evil Oil Apologist
Shall check both.
Merry Christmas!!!
Old Dec 25, 2011 | 11:31 AM
ajrothm's Avatar
ajrothm
Definitely loosen the two bolts on the h pipe to muffler connection, adjust the tips then tighten the bolts...That will get them straight.
Old Dec 25, 2011 | 12:30 PM
1FUNC5's Avatar
1FUNC5
Old Dec 25, 2011 | 03:42 PM
Z06supercharged's Avatar
Z06supercharged
I finally gave up on straightening my B&B Bullets. Then I looked at some pictures of my car new and the stock pipes werent even straight by far so I just didnt care anymore they were off..
Old Dec 25, 2011 | 03:46 PM
RC000E's Avatar
RC000E
Yeah...keepin these cars exhausts straight is near impossible. I put my BB's on dead straight and tight....one rip down the road and they were crooked. I can manage to shove them semi straight with my foot at shows/cruises...lol.
Old Dec 25, 2011 | 06:28 PM
Evil Oil Apologist
Ah HA! I get the drift. I jacked the rear end up and looked at the muffler area. Geeez, saw no way of accessing anything.
I need to take a look back at the X pipe (not H). I have LG PRO headers and pipes back to the TI. I'm guessing there's still some room for adjustment.
Old Dec 27, 2011 | 08:58 AM
Evil Oil Apologist
Default Update with question
Wasn't able to fix it, but I did notice what was significant. The tip that is low, the pipe before the big up and down in back was pushed up. The pipe in front of that was also pushed compared to the other side. I'm guessing an encounter with a speed bump at the winery (they use it to hold gravel in their driveway) was the culprit a few weeks back.
Looks like the fix is jack the car up, install jack stands, loosen bolts a tad back to the X piple (including X pipe), jiggle and pull down (starting at the X pipe and working my way aft). That tip, which is down, should go back to the correct position. Tighten. Have a beer.
Simple question, but do I have the concept? And no to having a beer half way through the procedure.
To Eneven exhaust tip issue
