help with 98 coupe missing fuses
Old Dec 28, 2011 | 06:44 PM
hopetogetvette's Avatar
hopetogetvette
Default help with 98 coupe missing fuses
Hi I was fixing hvac issue by removing fuse 27 so that's when I noticed I was missing fuses.
The fuses I'm missing are under the hood they are as follows
#1 rrfoglp minifuse
#7 rtd minifuse
#41 rtd micro relays
#37 rrfoglp micro relay
#51 maxifuse rtd
And under passenger fuse box the chime micro relay
Can anyone tell me why they might have been pulled and not replaced
My vette does have fog lights and they work
Thanks guys/girls
Old Dec 28, 2011 | 10:19 PM
#1 rrfoglp minifuse This fuse if for rear fog lamps - Export models
#7 rtd minifuse This is blank from the factory.
#41 rtd micro relays This is blank from the factory.
#37 rrfoglp micro relay For rear fog lamps - Export models.
#51 maxifuse rtd This is for Selective Ride Control if your car has it.
All this info is in the owner's manual. If you don't have one, you can download one from www.gmpartshouse.com - it's free.
Old Dec 28, 2011 | 10:51 PM
CatCam's Avatar
CatCam
Vetteman Jack -- a walking C5 encylopedia!!
Old Dec 29, 2011 | 09:04 AM
hopetogetvette
Thanks for your help guys
Old Dec 29, 2011 | 09:35 AM
Correction - 8VETTE7's post made me think a bit:
When I gave my answer above, I was mistakenly looking at an '03 owners manual - should have been looking at a '98 since that's what you have and they are somewhat different. Here's what the owners manual that I downloaded says for those fuse locations:
1 - this is listed as ABS TRANS - whatever the heck that is.
7 - Selective Real Time Damping - if you have this on the car, there should be a fuse installed in that slot (F45 option on the option code sticker)
41 - Same as #7.
37 - Micro relay ABS TRANS - again, not sure exactly what this is. Dealer would know.
51 - Owners manual says it is blank from the factory.
Chime mirco relay - did not see one labeled as that. What fuse is it in the box?
Sorry about the mistake.
Old Dec 29, 2011 | 09:46 AM
hopetogetvette
41 - Same as #7.
Hey no problem we are only human lol I looked up the chime one its inside the vette. Know I know why my car doesn't warn me if I leave my lights on or key in the ignition lol
To help with 98 coupe missing fuses
