key fob question
Old Jan 1, 2012 | 05:31 PM
apple61's Avatar
apple61
2nd Gear
Default key fob question
just installed new car battery, and now key fob isnt working.
can anyone tell me what happened?
Old Jan 1, 2012 | 06:52 PM
65GGvert's Avatar
65GGvert
Most likely lost sync. Turn on the ignition and hold down the lock and unlock buttons on the fob. If the horn honks, you're good. If not, you'll have to reprogram the fob through the DIC. Only takes a couple of minutes and the instructions are in the owner's manual, or you can search on the forum. The instructions have been posted many times. But, try the resync procedure first.
Old Jan 1, 2012 | 06:59 PM
RV13's Avatar
RV13
After my battery died and I had to charge the vette to get it started, my key fob stopped working. I did the "turn on the ignition and held the lock/unlock buttons" and it worked! Took about 5-10 seconds, but then heard the honk.
Thanks for the suggestion.
To key fob question
