Engine Comparment Paint Type.
Old Jan 2, 2012 | 10:23 PM
Dale002's Avatar
Dale002
Default Engine Comparment Paint Type.
Which type of paint is recommended for painting engine compartment pieces?
Old Jan 3, 2012 | 08:24 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Hi temp, plastic primer is very important..............
Old Jan 3, 2012 | 08:54 AM
Dale002's Avatar
Dale002
Do they make factory exterior colors in high temp? I'm looking for the colors black and Blue.
Old Jan 3, 2012 | 09:14 AM
tomringo's Avatar
tomringo
From: Richmond VA Everyone should have a VetteGuard
What I did was to wash well with a detergent soap, sand to your desired smoothness, wash with soap, then use a good plastic adhesion promoter, then prime and spray. I used paint/primer from these guys -www.automotivetouchup.com. Will match your color code perfectly, not high temp but should not need it for your plastic engine parts. Others on here have used paints from auto parts and big box. Important step is the preperation, want to be sure to get all the oils off the pieces even new pieces have some on them. Do a search there's plenty of info. "Painting Plastic Parts". Good luck with your project
Old Jan 3, 2012 | 08:39 PM
Regular automotive paint will hold up just fine - base coat/clear coat. Just be sure to use a good primer first.
Old Jan 3, 2012 | 09:33 PM
swpowell's Avatar
swpowell
I used krylon and it came out great. No Hi temp stuff at all.
Painted mine more than a year ago and still looks like it was just painted.
Old Jan 3, 2012 | 10:02 PM
02koolC5's Avatar
02koolC5
I used dupi-color paint and testors model enamel, krylon matte clear ...prep is the key, soap and water and de natured alcohol for cleaning.
Apr 2011.... daily driver and holding up well.
Old Jan 3, 2012 | 10:45 PM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
This is my wife's car. I just used standard car paint on the painted parts. Same as used on the interior parts and the exterior.
Most important is good primer and prep, prep, prep....
Added some pinstriping to a few pieces.
To Engine Comparment Paint Type.
