How can I fix my targa top leak??
Well I just hate it when my top leaks and I dont even know about it.I walked to my car and turned it on from a 2 month sit and I got inside and theirs some kind of mold barely showing on the pass side door panel so the only thing that would cause it to leak would be the top.Is their a company that sells them or any method that I can restore the weather stripping..Oh and its a coupe thanks
There are drain holes in the bottom of the door. make sure those are clear.
Additionally, pull the door panel and check the trapezoid shaped inserts. If those are cracked and the drain holes are plugged, you will get water in the car.
2002 C5 (05-29-2019)
Received 19,307 Likes
'20-'21-'22-'23-'24
Since this has been necro'd a few times... I'll take a copy of the word files as well if they exist still. velikovsky@pm.me thanks.
Hi All, my windows are leaking on both sides. Looks like the rubber is degraded. I ordered the window top peices from Corvette Rubber company. Link: https://corvette-rubber.com/
I will keep you all posted on the receipt and install.
1SharpGent (01-30-2024)
Know it's an old offer, but could I get that document as well if it's still floating around? Passenger side leaking like crazy!!
chrisjpb04@gmail.com
