adding sub and amp to 04Z
Old Jan 12, 2012 | 02:20 AM
Badd LS6's Avatar
Badd LS6
Default adding sub and amp to 04Z
Hey guys i'm going to be adding a sub n amp to my 04 z06. I will be using the stock head unit. I've tried searching through the audio section and read that i can not use a high-low converter on the speakers due to the bose processor not sending low frequencies to the speakers..Atleast thats what they said about the rear speakers..i dont believe my 04z has rear speakers?? i never looked lol...
I saw someone mentioning using the SVEN2...http://www.amazon.com/Peripheral-SVE.../dp/B000GAWS4A
Does anyone have any tips or write ups on how to accomplish putting a sub n amp in a c5z with using the stock headunit? any help or tips would be greatly appreciated! Thanks!
Old Jan 12, 2012 | 07:43 AM
tsbbzm's Avatar
tsbbzm
Old Jan 12, 2012 | 02:28 PM
Badd LS6's Avatar
Badd LS6
Old Jan 12, 2012 | 05:53 PM
guido7834's Avatar
guido7834
Don't do it! lol My kid just put that stuff in his 03 Impala. Talk about annoying!
Old Jan 12, 2012 | 05:55 PM
Badd LS6's Avatar
Badd LS6
im 23..it's not annoying to me just yet
Old Jan 12, 2012 | 06:13 PM
c4cruiser's Avatar
c4cruiser
Contact C5 Bearsfan, a CF member and supporting vendor. His business is audio products and he will happily help you with your ideas and questions.
Old Jan 12, 2012 | 06:32 PM
Turbopower87's Avatar
Turbopower87
I just dug through my folder for things I've done ot the Vette and found that I installed a "PAC AOEM-VET1" in order to plug the amp for my sub into the stock head unit. Do a search for that and I'm sure you will find the answer to your questions. Mine says 97-01 on the back but it has worked fine in my 04 coupe for 3 years now. I DO have rear speakers so I think you will be just fine.
I'm pretty sure I asked questions on here about this before I did my install years ago so you may even dig up my old post. Having never done an audio install before it went very smoothly. Good luck
Old Jan 12, 2012 | 11:21 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
This is exactly what I did a few years ago when I installed a sub and amp in my Z. The PAC plugs into the back of the stock radio, and then the stock harness plugs into the PAC. The PAC allows you to run RCA cables under the shifter area and center console and down to you amp, which I recommend you mount behind the passenger seat on the back wall. DON'T FORGET TO MOUNT A 3/4" MDF BOARD TO THE BACK WALL BEFORE YOU MOUNT THE AMP!! If you mount the amp directly to the back wall, you WILL drill right into your fuel tank, which is bad . Mount the board with Liquid Nails glue. To wire the sub, you need to splice into the rear speakers (yes, your Z has rear speakers) and run speaker wire under the rear carpet to your sub. The power wire runs along the passenger side door jam and under the floor board through the rubber gromment up under the passenger footwell into the engine compartment and into the battery.
I think I have a few threads in the Audio section where I talk about the wiring. There are other good threads there, as I recall. Good luck!
Old Jan 13, 2012 | 03:12 AM
Badd LS6's Avatar
Badd LS6
i will be ordering the AOEM tonight..My only question is why would i need to tap into the rear speakers and run speaker wire from the speaker to the sub if i'm taking the low frequencies from the AOEM tapped into the headunit going to my amp? I'm not new to installing systems, i think your referring to running highs and lows to the sub..I only want the Low frequencies (bass) going to the sub.
Old Jan 13, 2012 | 07:58 AM
raydawg357's Avatar
raydawg357
Once you pull your OEM radio, the power harness is made up of 3 sections. In the bottom section of the harness, you will find your rear speaker wires. They are: Brown (RL+) and yellow (RL-), Blue (RR+) and Lt Blue (RR-) These are the the wires you need to tap into for your signal. When splicing into wires I like using the Military Splice method. You will have to tap into your fuse box for the remote turn-on power for your amp.
Old Jan 13, 2012 | 01:11 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
I have another couple nice options as well that requires no removal of radio now. Just found these at CES
More info coming this weekend maybe next week
Dennis
Old Jan 13, 2012 | 01:57 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
Dennis
Old Jan 13, 2012 | 02:04 PM
Badd LS6's Avatar
Badd LS6
Dennis
dennis i just placed an order last night for the AOEM
Old Jan 13, 2012 | 02:05 PM
Badd LS6's Avatar
Badd LS6
ok now this is getting confusing..people are saying the AOEM is plug and play.now people are saying i have to tap into wires?? lol
raydawg are you referring to NOT USING THE AOEM..my original plan was to use a high-low converter and tap it into the speakers..BUT i reead that the bose system filters out the low frequencies to the rear speakers.
again my car is a 04Z06.idk if they changed it up or not..the stuff i was reading was pretty old.
Old Jan 14, 2012 | 06:22 AM
0Double D Mods
Former Vendor
Will get it out this week. I am a little backed up on orders from being gone the last 4 days so heading in shortly to get things going
He is wrong on taping the wires.
You do not need to do this with the aoem-vet1
I have 2 new options I am going to be testing out that will require this. but the aoem-vet1 will not need tto do what he says.
Old Jan 14, 2012 | 03:39 PM
Badd LS6's Avatar
Badd LS6
awesome..thanks dennis! i can't wait!!
Old Jan 14, 2012 | 03:53 PM
WHoisu05's Avatar
WHoisu05
Default Head unit
I don't know if it's the same set up but when I used to have my z28 car toys installed amp and sups and had to disconnect the rear speakers bc I used my stock head unit. I have 2 tens and a 1200w amp in my 02 z06 now And it sounds awsome car toys build a custom box and all but I had to change my head unit for it to work
To adding sub and amp to 04Z
Old Jan 14, 2012 | 03:57 PM
BLKOHZ06's Avatar
BLKOHZ06
He just does not play good music, I am assuming. Once you have a nice system installed you will never go back to a factory set up. Getting a new head unit will make it much nicer.
Old Jan 15, 2012 | 01:13 AM
WHoisu05's Avatar
WHoisu05
Old Jan 15, 2012 | 05:52 AM
liveaboard74's Avatar
liveaboard74
You have another option. A 12" bass tube will fit perfect down in the hole. Amp is mounted on the back wall. Before and after photos. Just wanted something different and it don't look half bad.
