pozesd99's build thread
Old Jan 12, 2012 | 10:46 AM
michaelfrench's Avatar
michaelfrench
Default pozesd99's build thread
My clutch went boom in the middle of a brakestand in the waterbox at firebird. Gives me an excuse to go faster. I will update this thread with updates on cam/ supporting mods/clutch build. Using a centerforce dual friction clutch and a 234/244 .598/.612 114+4 lsa, lunati dual gold spring retainers, keepers and trickflow pushrods, ls7 lifteres and upgraded ls9 timing set.
trickflow pushrods (installed already) lunati dual gold springs (installed already) cam is a 234/244 .598/.612 114+4 lsa.
Old Jan 12, 2012 | 10:59 AM
SVTBAIT's Avatar
SVTBAIT
2015 C5 of Year Finalist
Sounds awesome. Keep us posted! Will you be doing everything yourself?
Old Jan 12, 2012 | 11:03 AM
Z06ster's Avatar
Z06ster
Looking forward to the seeing the progress...
Old Jan 12, 2012 | 11:18 AM
michaelfrench
Yup myself and friends
Old Jan 13, 2012 | 11:07 PM
michaelfrench
quick update:
most parts came in to me today
head gasket, waterpump gasket, oil pan gasket, header gasket, slave cylinder, ls7 lifters, gm motor mounts
on the way are the head bolts, remote clutch bleeder, resurfaced flywheel, ls9 timing set
any who time for pictures:
Old Jan 14, 2012 | 12:16 AM
Best of luck getting everything back in shape - will be tuning in for the progress reports.
Old Jan 14, 2012 | 05:50 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Nice new go fast parts
Old Jan 24, 2012 | 08:19 PM
michaelfrench
Well I have run into a few little problems. Nothing too serious though. The motor is out, slave has been replaced, flywheel has been resurfaced, motor and all parts cleaned up inside and out, new cam installed, lifters intalled, and ls9 timing set and melling oil pump has been installed.
Dealership gave me the wrong head bolts even though the vin was provided to them! I did forget to buy a front main seal.
Only things left to do are to install heads, timing cover and front main seal, and install all accessories, flywheel, and clutch to the motor. The new motor mounts need mounting, and then the motor is good to drop back in!!! Hope to have it done by friday
Old Jan 30, 2012 | 02:38 AM
michaelfrench
Well, cam swap is done. Went to go for a test drive but looks like something in my diff was the culprit. Removal starts tomorrow. :-(
Vid coming soon
Old Jan 30, 2012 | 02:56 AM
michaelfrench
To pozesd99's build thread
