[Z06] Rear end "whine".....
Old Jan 17, 2012 | 04:10 PM
silvzo6's Avatar
silvzo6
Default Rear end "whine".....
I've developed the notorious diff whine,higher pitch faster the speed under load,changed the fluid helped some but not much,What is the worst that can happen to the diff other than the progressive wear of the gears if i drive on it for a little while longer? Its mainly used for "street" use here and there
Old Jan 17, 2012 | 04:29 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
sounds like a diff issue or rear torque tube bearing going out.
Old Jan 17, 2012 | 04:32 PM
silvzo6's Avatar
silvzo6
how do you figure out which one it is? or how can u figure out if the torque tube bearing is going out?
To Rear end "whine".....
